Question about Sony VAIO VGN-S58CP/B (4400 mAh)
How to remove coms battery - Sony VAIO VGN-S58CP/B (4400 mAh)
  • 1,087 Answers
You dont that are fused to the motherboards on laptops.
Posted on Apr 01, 2015
How do you change the batteries in a norelco 7735x razor?
Remove the translucent back cover to reveal 4 screws. Remove those screws and a 5th screw located in the 'cap' on the bottom of the shaver. This will allow you to remove the lid of the battery compartment.
Use the information at the shaveroutlet.com video below fro battery installation
https://www.youtube.com/watch?v=2oAnLpvdYqQ
Batteries for your model can also be found at shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Oct 19, 2014 | Norelco 7735X Electric Shaver
Need to replace the batteries in a norelco 5821xl
norelco battery replacement NiCd two batteries pack for electric shaver philips norelco 5821xl replacement parts.
Feb 06, 2011 | Norelco Reflex 5821 XL Electric Shaver
PROBLEM: WILL NOT TAKE A CHARGE. DEAD BATTERIES (?) - WOULD APPRECIATE PROCEEDURE NEEDED TO REPLACE BATTERY(S) FOR NORELCO ELECTRIC SHAVER MODEL 5821XL. SHAVER IS SEVERAL+ YRS. OLD AND IN EXCELLENT...
Dead batteries will cause the shaver not to charge. Batteries for model 5821XL can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To change, remove two screws on back and remove back cover. Remove plastic clip that is in the way of removing batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 31, 2010 | Norelco Reflex 5821 XL Electric Shaver
Not charging
Dead batteries will cause the shaver not to charge. Batteries can be found at shaveroutlet.com. See link below
Dec 27, 2010 | Norelco 5601 X Electric Shaver
Batteries dead how do you replace them?
For model 5865XL, you will find batteries for your shaver at shaveroutlet.com. See link below
To replace, you first need to remove the back cover by removing the two screws on the back. One of theese screws is accessed by pushing up the trimmer. Once back is removed, you need to remove the two white plastic support pieces to properly access the batteries. You can lift out the circuit board and unsolder the old batteries but it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If this is not something you can do yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Aug 22, 2010 | Norelco 5865 XL Electric Shaver
What is the procedure for replacing the batteries in the Remington Titanium R 9500?
There are three screws on the back of the shaver to be removed. One is easy to see. The second is visable when you extend the trimmer. The third is hard to get to and the trimmer must be disjointed at the top to get to it. Once all three screws are removed, you can remove the back cover. There are two batteries. To remove them you will need to unsnap and remove the long metal clip and then unsolder the wires connected to the batteries. There may also be a gummy substance holding a wire to the side of one of the batteries. You will need to use a razor blade to seperate it off along the side of the battery. Once the old batteries are removed, you can solder in new batteries and ten reassemble the shaver.
You will find batteries at shaveroutlet.com. See link below. You will need to order two.
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
If you are unable to do this repair yourself, shaveroutlet.com can do it for you. See link below.
Mar 15, 2010 | Remington Titanium SmartSystem R-9500...
I need to know how to remove the battery from a norelco mod #
To get to the batteries, you will need to flip up the lotion packet cover on the back and remove the lotion packet if there is one. You will see four screws on the back. Remove these to take off the back of the shaver case. Once this back case is removed, you will be able to see the battery pack. The circuit board can be lifted up slightly for better access to the batteries.
To replace the batteries, you will need to do a little soldering. For easy replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs.
Batteries for this shaver can be found at shaveroutlet.com. See link below.
Feb 22, 2010 | Norelco Advantage 6735 X Electric Shaver
How to open Philips shaver 7110X to replace batery
Remove 2 screws on the back to remove outer cover. Once removed, you will see 3 more screws that must be removed on the inner cover. Remove screws and cover to get to the battery.
When installing the battery, I suggest that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
You will find a battery for your shaver at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Feb 12, 2010 | Philips 7110X Electric Shaver
A6 Battery removal
You should check either - www.audiforums.com www.audiworld.com or www.audizine.com, register and search the forums, should be good info. also check under the battery, man audi cars have secondary brackets underneath to hold the battey in place.
Nov 25, 2008 | 2001 Audi A6
Sony VAIO VGN-S58CP/B (4400 mAh) Logo
113 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
