Question about Xerox Phaser 6110MFP All-In-One Laser Printer
Invalid Black Toner Xerox Phaser 6110 MFP
Brand new toner cartridge, gives the error that toner is invalid and will not print. If I take it out, and shake it, it prints fine but after a couple of pages gives error again. HALP.
  • john_dejesus Jun 23, 2009
    I used the reset feature in hte user manual page 43 or so. Set it to reset all, problem solved.
  • 184 Answers
Reload the driver again and if it persists, change the toner
Posted on Jun 23, 2009
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
09-800 Invalid Toner Cartridge Message
Verify that you are using oem Xerox toner cartridge. If you're using an Oem Xerox cartridge and still getting this error it could also be the Crum Board, part number 140N63302.
Apr 11, 2013 | Xerox Phaser 3635MFP/X Multifunction...
The secretary ordered 3rd party toner cartridges for a Xerox Phaser 6130. After replacing the black cartridge the "invalid cartridge" message comes up. Is there a way that we can use the 3rd...
If you get the "invalid cartridge" message, try completely turning off and unplugging the unit. Then remove the cartridge, close the door and after at least 30 seconds, restart the unit. Then reinstall the cartridge. This worked for me!
Sep 26, 2011 | Xerox Phaser 6130 Laser Printer
My xerox phaser6110 shows a massage "invalid black toner" while using a generic toner. what could be the problem?
The toner has a chip inside. The chip could be damaged or not reset properly. Please bring it back to where you bought it from to get it exchanged.
May 07, 2011 | Xerox Phaser 6110 Laser Printer
When the red light blinks on the printer what does it indicate-model-xerox phaser printer 6110
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
Apr 06, 2011 | Xerox Phaser 6110 Laser Printer
How to fix invalid black message after replacing a toner
how to fix invalid black message after replacing a toner And I have the same problem. I buy 4 new toners and for each one i get notice from xerox 6125 invalid black, or invalid yellow. What do I need work?
Feb 26, 2011 | Xerox Phaser 6125 Laser Printer
Problem with Xerox Phaser 6110 black toner.
Yeah it is a problem with the chip that is on the cartridge. You can go to the Xerox.com site and contact them directly by phone or e-mail.
Just once at the xerox.com site, select your country.
Jan 06, 2010 | Xerox Phaser 6110 Laser Printer
Noise after change color cartridges
is the toner cartridge and have a manufacturing defect or the toner cartridge scouer adaptable and look
Mar 07, 2009 | Xerox Phaser 6110 Laser Printer
Xerox Phaser 6110 claims new toner cartridge is empty
Could be many things...depends on the exact nature of the problem. Where the machine states "Invalid Toner" either the machine itself or the toner cartridge may be the wrong "region". i.e. has been sold in the wrong country..the initial toners will work but as soon as you put new ones in they will give this message. If the machine is still displaying "out of toner" then either the toner cart itself is faulty (assuming they are original Xerox carts) or the Image Unit could be faulty (the bit they plug into). Failing that, it will be a faulty Main PCB. The Toners on these have a crum chip, so they cannot be just re-filled and some that may seem "compatable" will not work either.....
Mar 05, 2008 | Office Equipment & Supplies
Xerox Phaser 6110MFP All-In-One Laser Printer Logo
3,241 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
