Question about Brother P-Touch - PT-1280 - Home and Office Labeler, Refurbished Printer
My PT 1280 won't cut. Can I get a new blade? - Brother P-Touch - PT-1280 - Home and Office Labeler, Refurbished Printer
    President:
  • 2,306 Answers
The parts list doesn't show a blade alone, part # LN6775001 is the cutter lever, could be what you need. About $3.00
Posted on Jun 23, 2009
Blade spinning loose. Won,t cut grass. Won,t tighten
Most have lugs the blade fit in and washer on bolt.
Feb 09, 2015 | Garden
Bandsaw blades keep popping off,could it be heat related?
Blades slip off the wheels on these saws is because one or both wheels are not turning true to the blade. This can be caused by:
- Missing or worn tires on the wheels. The rubber tires have to be on the wheels and they have to be in good condition.
- Occasionally the screws holding the sprocket on the driven wheel come loose and the wheel will wobble causing the blade to come off.
- Both wheels ride on bearings and shafts that, if seized, worn or broken, will let the wheel wobble enough that the blade won't stay on.
- If the blade is stretched or twisted from use it won't stay on very well.
Aug 06, 2012 | Dewalt DWM120 Heavy Duty Variable Speed...
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
I have just had all the blades sharpened for my clippers but they won't cut my dog's fur. Never had a problem before. Can you please help?
It is common to that a Blade Sharpening Service return your blades just as blunt as before, or even worse.
I advise that you try a new Blade Sharpening Service; trying out only a couple blades to begin with.
I recommend a mobile/on-site sharpening service.
Sep 15, 2011 | Oster Golden A5 2-Speed Universal Motor...
I would like owner's manual for the brother model #PT-1280,printer
You can go to brother-usa.com and click on the "support" tab, then scroll down a little and you will see "manuals". Click on that and enter the model # and you should be able to download the manual.
Jun 09, 2011 | Brother P-touch PT-1280 Thermal Label...
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
Brother PT1280 P-touch Machine User's Manual Download
You can download and print the instruction manual in PDF format from Brother PT-1280 support website by clicking this link
On the page which opens, click on the 'Download' button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader. Thanks for using FixYa
A 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Brother P-touch PT-1280 Thermal Label...
Brother HL 1280
is the actual model is Brother PT 1280 .. it';s a labeling p-touch..if yes..then you can download the user manual here...
http://www.brother.com.my/my/productDetail.asp?model=PT-1280&Rnum=241294
May 24, 2010 | Brother HL 1260e Laser Printer
How do you set the right margin?
Apparently it cannot be set. That is the length between the print and cut mechanisms....
Jan 29, 2010 | Brother P-touch PT-1280 Thermal Label...
Have Downloaded "instructions" for PT-1280.................
1. Your site and the search engine I used state "free" help - no plan or package mentioned.
2. My question was in regard to a PT-1280.
3. I simply asked if anyone knew how I could get the instructions for this label maker larger as the download has every thing squeezed on 2 pages with the type so small it can't even be read correctly without straining with a magnifier. It comes as a PDF file and cannot be cut - stretched or enhanced anyway that I know to do.
Thank you for your email asking if I would like find out about your plans. The questions I have would be related to my equipment I use at work and I am not even going to consider digging in my pocket for anything. The equipment I use at home is wireless and works excellently and as I stated originally I do everything - including labels and programming from my personal computer.
Jan 15, 2009 | Brother PT-1000 Thermal Label Printer
Brother P-Touch - PT-1280 - Home and Office Labeler, Refurbished Printer Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
