Question about Maytag PYE2300AY Electric Dryer
I need to know how to remove the back of my Maytag performance dryer model# PYE300AYW to replace the belt how do I do this?
  • jesserno Jun 23, 2009
    Yah I found that too but both diagrams are not the right Diagrams for this unit ,Still confused?
    President:
  • 744 Answers
Hi here is a link with instructions on accessing a maytag dryer cabinet.
http://www.applianceaid.com/may-apart.html
Hope this helps.
Good Luck!
Posted on Jun 23, 2009
  • Mike Price
    Mike Price Jun 23, 2009
    Ok I just pulled up a schematic of that dryer…I have worked on this one several times before, There actually is no way to replace the belt from the rear, have to squeeze your arm through the front and re-install the belt and pulley. I’m sorry I am not more help on this one but I have one or two scars on my arm to attest to the fact it’s a pain changing the belt on this model.
    Please feel free to comment again if i can help you again in any way :)
Replace belt
You can order a replacement belt if you know the make and model. Best to have a helper when replacing as it is hard to hold everything in place single handed. Are you sure it is the belt? Need to lift the top and remove the front in most front loaded "simple" dryers.
Jan 02, 2014 | Maytag PYE2300AY Electric Dryer
Is their a picture diagram of how to replace dryer belt on maytay dryer model LDE9824ACE?
Maytag belts are counter intuitive. They give me trouble even though I've done hundreds of them. Your model should look like the one in the picture below. I assume you know how to get to the belt but if not there are 2 screws at the bottom of the front panel you remove. Then lift the bottom of the panel up and out and it will come off. You will have to undo some other brackets to get to the drum
The belt goes on 'upside down' on maytag, meaning that the tread faces up. You should be able to see where the old belt was riding from the marks on the drum, just make sure it doesn't slip into the groove. Put it back together and undo the panel on the back, you should see this.
That should be enough to show you where it goes. Pull the pulley over to release the tension and align the belt as shown. Replace the cover and enjoy your dryer.
Cheers
Oct 06, 2010 | Maytag Dryers
WORN BELT ON MAYTAG ELECTRIC DRYER
Remove the two brackets on the back holding the top on. Then pry the front part of the top off with a flat screwdriver. Next remove the electrical connectors. The remove the front panel. Then pull the drum out. Install the belt and push the drum in place placing the belt correctly into the tensioner for the belt
May 10, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
Belt replacment
Here is a diagram from kenmore corp. that should help you out
Maytag Dryer Belt Routing
This is the most common belt routing found on most Maytag brands clothes dryers.
Since you will have everything disassembled to change the belt, this is an excellent opportunity to vacuum out the cabinet to remove dust and lint and perform preventative maintenance on your dryer. When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Dec 04, 2009 | Kenmore 66862 Dryer
Maytag clothes dryer cannot get to the pully, Is there an easy way to remove the panel, I need a diagram
Unfortunately you'll most likely have to remove the whole back panel. But I have no idea because you need to tell us which model you have!
Maytag has made dryers for probably over 60 years, there's more than just one model!
Sep 19, 2009 | Dryers
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Pye300ayw electric dryer dryer starts however it wont heat on an
Hi, unplug the dryer, there is an electric element on the back of the dryer, it should be covered with a removable metal cover, remove this cover and plug it back in turn the dryer on if the element does not heat it is probably bad, also check if there is a broken spot or if the element has shorted out, Hope this helps.
Mar 18, 2009 | Maytag PYE2300AY Electric Dryer
I believe the belt on my maytag electric dryer model LDE412 is going out. How to I get to the belt to remove it for replacement? Through the front of the dryer or the back?
Remove the front panel(s). and you will be able to remove the top panel, which will give you access to the top of the drum and be able to replace the belt. There should be a small pulley at the bottom of the dryer where the belt attaches to, as well as around the entire drum.
Jul 03, 2008 | Maytag Dryers
Maytag PYE2300AY Electric Dryer Logo
288 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
