Question about Saeco Vienna De Luxe Espresso Machine
Saeco royal Blowing the fuse
SOURCE: saeco cappuccinatore not taking milk, instead blowing some steam into milk
Try this, the valve diagram shows that you twist the knob, but you left it up and down to adjust the flow. You could also check that the container you have the milk in, is lower in height than the cappuccinatore to help it siffin the milk up from its container. Make sure the cappuccinatore is fitted correctly pushed in fully and half fill a cup with milk and pull the valve adjuster up a small amount and push the button. It should start pushing steam out the cappuccinatore and then within a few seconds it should start siffining milk up the tube.
Cyril
Posted on Oct 01, 2008
SOURCE: saeco royal proessional does not get power when i turn on machine
you can check the fuses on the power board..there are 3 pcs of fuse ..check the microswitch on the side door,waste container and the brewing unit...it may solve your problem.
Posted on Aug 17, 2009
  • 1089 Answers
SOURCE: saeco royal digital part 0701.R05.050 broke how
HI
Its called a thumbscrew. You have pulled the nut that was molded into it out. Don't use the key to install the new one. That is why they call it a thumb screw. Finger tight. Should be able to get it from one of the online vendors. http://www.partsguru.com carries it. Wholelattelove. 1st line.com
Posted on Oct 26, 2009
Testimonial: "thanks "
  • 1089 Answers
SOURCE: my saeco royal professional has no power, no lights. What's up?
Hi
First I would check the switch on the bottom left side of the machine and make sure that it has not been turned off.
If it is on you may have a fuse out on the board. It is a very special fuse. It is a 35Ma timed lag fuse When we change them we put in a 50Ma Timed lag fuse with no problems, because the 35MaT is hard to find.
Posted on May 08, 2010
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
My saeco royal professional has no power, no lights. What's up?
Hi
May 05, 2010 | Saeco Royal Professional Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
Where is the fuse on a saeco royal professional unit? i lost all the power on my espresso machine and i'm assuming the fuse is the problem but i cannot seem to locate it on the unit itself?
There is a special *amp fuse inside on the back bottom of the machine. It is next to the pump. There is a gray cover over the power filter where the fuse is ;located. You can see the power wires going into the cover. There is also a special .35maT fuse that is on the back of the power board.
Feb 12, 2010 | Saeco Royal Professional Espresso Machine
Can you buy a repair manuel for a saeco royal
www.manualnguide.com/.../manual.../saeco-royal-professional-instruction-manual.html -try tis link
Jul 23, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
Saeco royal proessional does not get power when i turn on machine
Jul 12, 2009 | Saeco Royal Professional Espresso Machine
Saeco cappuccinatore not taking milk, instead blowing some steam into milk
Cyril
Sep 27, 2008 | Saeco Royal Professional Espresso Machine
No power -- where is fuse?
Fuse is inside the machine. Looks like a black wire thats fat in the middle.
Its either that or the main board blew. I pray it is the fuse because saeco doesn't sell the royal boards anymore from what i understand.
May 26, 2008 | Saeco Royal Professional Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
27 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
