Question about LG Office Equipment & Supplies
Why is my LG Projector overheating?
I have a LG AH215 720p projector which is just under 3 years old. It has a new bulb that is less than 2 months old. A week or so ago it started overheating after about 15mins of use. Firstly the orange light indicating overheating comes on after about 10mins of use, Followed by about 5-10mins of the fans going haywire. The projector then goes into some kind of cool down mode with the light flashing orange and the fans still going crazy, but now with the bulb off. As I have only recently shelled out for a new bulb I would really like to sort this issue out. I regularly clean out the projector with compressed air, so this is not a dust buildup issue. All the fans seem to be functioning. Any help would be amazing!
4 Suggested Answers
  • 6 Answers
SOURCE: HD 70 DLP Projector problem
Hi, My name is Doug Stanko.
I had the same issue and fixed the problem.
All you have to do is take a few screws out..... and blow out the inside VERY well with pressurized air. I have a compressor... and I set the regulator to 50 psi. But the KEY IS TO have the covers off so you can get between the circuit cards and blow them out. They were incredibly dusty. Even after I blew through the side vents.
I agree with all of you that say it is overheating. You are right. There was so much dust on the fan blades them selves... I'm suprised they were still spinning at all.
And like most of you... first I bought the $300 dollar bulb... put it in and 10 minutes later it was doing the same thing flashing through the colors. So trust me.
There are 4 screws on the back. Take these out.
There are 2 small nuts on the back around the VGA input. Take these out.
There are about 5 screws on the underside (think one was on the bulb changeout portion). These have long copper colored bars that go all the way from top to bottom.
All these have to be removed. Then you can take it apart. AND I PROMISE YOU WILL SEE TONS OF DUST ALL OVER.
Make sure you blow out the parts between the circiut boards AND the fan unit.
Put it back together... and remember to make sure that little latch on the bulb change cover makes the click sound ( it is a switch that must close or the unit will not power back up )..... and it will work great again.
No need for a huge fan next to it. Although I will admit that is an excellent idea.
I did this 3 weeks ago and have been watching it with no issues.
If you do not feel comfortable taking the screws out yourself..... I would take it to your local TV repair store and just ask them to take the covers off and blow out all the dust... and give it back to you. No troubleshooting... no repairs... no replacements... just blow it out.
I was an electronic technician in the US Navy for 10 years... Now I work at a nuclear power plant in Illinois. BUT I PROMISE with a good phillips head screw driver and a small crescent wrench you can do this yourself.
Good luck and you are welcome. I know how frustrating this issue is. But this is the fix.
Posted on May 13, 2009
  • 38 Answers
SOURCE: Dell 1100MP Projector, unit stopped working, I
This is a very common problem with these projectors. The fans lock up and the units are out of warrenty. The fan you replace it with must be the exact same as the old one, even though it is the same as a 5$ computer fan. The processor will detect the non-dell fan and shutdown in the same way.I Havent been able to find any replacement fans that will work. I may be interested in buying your broken projector from you if you give up.
Email me at: nalexandrov251[A-T] and we might be abe to work something out.
Posted on Dec 08, 2009
  • 2237 Answers
SOURCE: LCD Ceiling-mounted projector keeps overheating.
canned air from the outside is good, but a lot of the dust collects on surfaces and bakes on. for best results, remove the top cover and blothe dust out of every nook and cranny, wipe it off of the fan blades, and make sure all of the fans spin well. you may need to replace the temp sensors if it happens too frequently. also, during the winter when the heat is on full blast, it tends to get very hot on the ceilings. is there enough air flow in the room? lastly, make sure they turn them off at the end of the school day. this will lenghten the life of the power supply and the lamp.
Posted on Jan 26, 2010
Testimonial: "Thank you! I was thinking about installing the extension arm that came with the universal mount to keep it further from the ceiling. Air flow is OK."
EP739 projector has been overheating the last 6 months.
Its getting old...and generating more heat...
There are fans inside the projector that **** in ambient
air and blow it across the parts...A quick fix might be
to lower the room temperatrue a few degrees...or
you could get a small fan, place it along side the projector
and have it blow additional air into the projector...
The projector is running at borderline temperature...
Also, make sure it is on a flat hard surface...and not
resting on a cloth or towel or rug...there isn't much space
between the bottom of the **** air in...and it
needs all that space...
You may want to make sure the AC line voltage is 110 -120 VAC
even a slight drop in this voltage will cause the projector to run
less efficient which means running hotter...
Jul 21, 2010 | Optoma EP739 Multimedia Projector
Infocus IN72 - blinking RED light
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Mar 03, 2010 | InFocus IN72 Multimedia Projector
Cinego is randomly shutting down
if it is overheating, blow out the projector with canned air. excessive dust keeps in the heat that the projector is trying to expell. also, make sure all of the fans are working properly. if it's cleaned out and the fans are running, you may have a main board issue.
Nov 29, 2009 | Radio Shack Cinego D-1000 Multimedia...
Liesegang dv 560 flex projector with a pulsating image
Ordered a new lamp at dealers cost ($140). Let's see if it was a malfunctioning bulb.
Oct 08, 2009 | Liesegang dv 560 flex LCD Projector
Projector keeps turn itself off
I have a Dell MP2300 with a bad power supply. Everything else is in excellent working condition. the bulb is less than a year old and has less than 500 hours on it. My asking prices are:
1. WITHOUT BULB: $50 shipping
2. WITH BULB: $150 plus shipping .
If you are interested, please contact me. I will also consider offers.
Bethesda MD - 301-588-7222
Jan 09, 2009 | Dell 2300MP Multimedia Projector
Blub out again
Hi there
Keep in mind that this is only a estimate - not true hours at all.
Does your Projector go in for a service every 3 months ?
If I were you I would take back the Projector to the dealer you purchased it from and ask them to test your Ballast ( lamp's powersupply)
Did they tell you to run in your new lamp for 12 hours straight ?
Feb 13, 2008 | Optoma H30 Multimedia Projector
IN76 Pojector Just Turned Off, Will Not Turn Back On
same thing on my in76. a color wheel had to be replaced. projector is less than a year old an all parts and labour was covered.
Dec 30, 2007 | InFocus Play Big IN76 Multimedia Projector
Shuts off
projector turns off after 30 seconds problem solution
Sep 16, 2007 | Sanyo PLC XU35 Multimedia Projector
Optoma hd72 bulb turning off
This is NOT a bulb problem unless your "lamp" LED is lit, which you say it is not. Many people have reported this problem with the Optoma 72. You can send it in for warranty service (it has a 2-year warranty) to get the lamp controller chip replaced, but the problem may recur. Optoma does not appear to have a permanent solution to this problem. My projector has broken exactly like yours TWICE in a year. I haven't even needed to replace the original bulb yet. :(
Nov 05, 2006 | Optoma HD72 Multimedia Projector
101 people viewed this question
Top LG Office Equipment & Supplies Experts
Jaime Hernandez
J.D. Browning
J.D. Browning
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
