Question about Health & Beauty
Sunbeam sdl900 scale - Health & Beauty
Healthometer change kg to lbs
With scales off. Hold select button for approximately 5 seconds, lbs flashes hit select to confirm
Apr 28, 2012 | Sunbeam Healthometer Body Fat and Weight...
Can I use distilled water in my Sunbeam ultrasonic sul496?
You most definitely can. In fact it's better than using tap water. As it doesn't have all the minerals and chemicals that tap water has, that cause scaling.
Thanks for choosing FixYa.
Sep 09, 2011 | Sunbeam Ultrasonic Humidifier
I am trying to locate an Owners Manual for my Sunbeam Controled Heat Sauce Pan model SP 5. Works fine as deep fryer but would like to know what else it can do.
I tried looking for the Sunbeam "SP 5" and came up with a digital scale. A web search for "Controlled Heat Sauce Pan" turned up a paper cookbook How to Get the Most out of your Sunbeam Controlled Heat Sauce Pan for sale for $9.95 (go to item 15 on the page).
Jan 05, 2011 | Sunbeam Crock Pots & Slow Cookers
Recently when I step on the scale I get and E
Try stepping off when you get the E and step back on after 5-10 seconds and see if it works.
Aug 12, 2010 | Sunbeam Healthometer Body Fat and Weight...
I have a Sunbeam digital scale and Model SDR520CO-01 We just recently moved. But somehow it doesn't work any more. Rarely we can get it work but very very slow and show strange pattern of showing letter E...
Incase anyone has this issue this is simply a case of not using the scale correctly.
You must first tap the bottom right corner of the scale for around half a second with pressure with your foot and then remove your foot. When the blinking has gone to 0.0 you may then step on the scale.
If you do not tap the scale and then wait for the 0.0 reading you will get an error reading. This was actually on a sticker on the product but I imagine some people remove it after purchase etc etc.
Jul 03, 2010 | Sunbeam Digital Scale HDL205KD01 ()
How do i reset each individual person
mcdevito75 here, There should be a button or knob close to the indicator you can press, turn, to return scale to zero for each person.
Jun 26, 2010 | Sunbeam Healthometer Body Fat and Weight...
4268 iron leaving residue
This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
Aug 04, 2009 | Sunbeam Irons
Need sunbeam/oster 4713/5710 rice cooker directions
All you have to do is pour white vinegar in the bottom, leave for about 2 hours and rinse and wipe clean!
Mar 20, 2009 | Sunbeam Kitchen Appliances - Others
Scale build up problem in iron
White vinegar and a toothbrush. You can clean the whole steam path with 25% vinegar to 75% water. Steam it through. Run plain water afterwards to rinse it out.
Feb 06, 2009 | Sunbeam Irons
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
