Question about Jura Capresso Jura Ena 5 2Cup Coffee Maker
How to disassemble Jura Ena5?
Water leaking from the bottom.
5 Suggested Answers
  • 60 Answers
SOURCE: open tap - filling system - close tap
Try using warm water in the watertank, important that the water is not too hot, it can cause leakage in the o-rings in the fluidsytem.
Repeat the procedure a few times, if nothing helps, turn off the machine and wait 1 hour and try again.
If you can`t get around this message, then the flowmeter needs to be changed.
Posted on Jul 12, 2009
SOURCE: Water leaking jura s9
I have solved a leak doing as suggested by hhmartins. There was noticeable white scale around a couple of connections and these were cleaned up.
Could there be a blockage? The pressure relief valve (small round thing) was easily removed and cleaned.
(I have posted my own puzzle about whether I've reassembled the brewing unit properly)
Posted on Apr 22, 2010
e-Guru
  • 3917 Answers
SOURCE: My Jura Capresso, Z5 is
Hi
The connectors on capresso machines are very tricky. The reason for the leaking could be to do with the seals. Take it apart and make sure all the rings and pressing clamps are in the right place. Also take a good look and on your hot water tank, and the pressure relief valve in back of machine.
Also it is recommended that the Jura coffee machines to be serviced every 2 years.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 10, 2011
SOURCE: My Jura Capresso Impressa E8 is leaking water
I have the same problem with my E9 and I have traced it to the diaphragm unit that is just distal to the pump itself. Apparently, the diaphragm is secured with a steel band (not stainless since it is rusty) that may hold seals or O-rings that break down. You can observe it leaking when pressure applied during brewing. The question is: can a new unit be ordered and if so, where?
Posted on Nov 05, 2011
Press steam fill water
You can check the water valve, it may become clogged. But you should not disassemble machine if you are not specialist. Contact Jura service center if your machine still under warranty.
Sep 25, 2013 | Jura Capresso Impressa S8 Coffee Maker,...
How to open for cleaning jura ena5 coffee machine
The question is, how to open the machine? I found elsewhere one should unscrew the back logo, but it is slippery. Seems like a special tool would be needed, but I did not find it.
May 06, 2012 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
My jura en9 pour spout clogged. How do I disassemble to clean out blockage? It is pour very slow and coffee is leaking out the sides of the spout.
Hi Eric
Can you get a pipe cleaner up the spout and clean?
Otherwise.... Take some photos and start unclipping & unscrewing
Thats how I replaced the Element in mine.
Check YouTube
Nov 08, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Leaks water
There are many possible points that the leak can be.
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Jun 10, 2010 | Jura Capresso CoffeeTEC 471 Coffee Maker
take it a part again, and make sure all the rings and pressing clamps are in the right place. Also take a good look and "IN" on your hot water tank, and the pressure relief valve in back of machine
Mar 24, 2010 | Jura Capresso Impressa S9 Coffee...
Open tap - filling system - close tap
Jul 10, 2009 | Jura Capresso Impressa E75 Espresso &...
Jura Z5 - no water being sucked up through the system
If you are holding the filled water tank in your hands does it leak? If no then the o-ring in the bottom of the hole on the machine where the tank sits is damaged.
If yes then check the spring and o-ring on the bottom of tank.
Apr 28, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Jura Ena 5 2Cup Coffee Maker Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
