Question about Kenmore 54701 Dehumidifier
My humidifier blowes hot air - Kenmore 54701 Dehumidifier
  • Kenmore Master
  • 2,760 Answers
If it's working well it should , unit should be removing all the moisture from air expelling out back , so its dry air
its when coils freeze up then you have a indication of problems
Posted on Jun 06, 2015
Fan barely turns
If the fan is barely turning, it could be the fan is bad. This fan blows air across a 2 coils.
May 29, 2014 | Haier HD456 Dehumidifier
I have a Kenmore Dehumidifer, model number 580.53650200 and it's been sitting around in the garage for a while. Before I plugged it in I ran the air compressor over it fairly well, blowing out the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 05, 2011 | Kenmore 5365 Dehumidifier
The dehumidifier is getting cold condensation on the top outside of the unit and no water in the bucket. Model BGD-510A. I cleaned the filter and the coils and still have this problem.
Kathryn, if you are operating it in a basement application, the problem is that air temperature at floor level, is colder than at shoulder level. Dehumidifiers struggle to work at temperatures between 40 & 65 degrees F (Unless they are Low Temp model designed for basement applications). And will ice up at times. Raising the unit up off the floor onto a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water, will usually resolve the problem.
If it's not a basement application, try lowering the humidity extraction level to 35%. In you have an analog unit, turn the control knob to Maximum.
I hope this helps you and thanks for choosing FixYa.
Aug 10, 2011 | Dehumidifiers
Classic dehumidifier cdr4500e blowing hot air
heatman101
Jul 12, 2011 | Danby DDR2509EE Dehumidifier
Cold air is coming out, instead of hot air. how can i fix problem thanks john
if you want hot air the you need a humidifier, it puts warm moist air into the room. used to put moisture in the air if your running a wood stove
Mar 04, 2011 | Kenmore 54701 Dehumidifier
The de-humidifier blows heated air. Is this normal?
yes, its normal.
Apart from the heated air blowing out, do you notice any kind of fault from the unit or is it malfunction in anyway as a result of the heat?
If the answer to the above question is NO, then there is noting to worry about.
Take care.
Jul 29, 2010 | Danby DDR586R Dehumidifier
Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Jul 27, 2009 | Kenmore 54501 Dehumidifier
My kenmore 50 pint dehumidifier 54501 runs but it does not taking in water
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
Jul 18, 2009 | Kenmore 54501 Dehumidifier
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
May 01, 2007 | Maytag M7DH65B2A Dehumidifier
Humidifier is very hot
doubt if there is a fault. if something gets cold ie freezing section then something else gets hot
Mar 18, 2007 | Fedders RDG40 Dehumidifier
Kenmore 54701 Dehumidifier Logo
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
