Question about Drills
How do I lock drill bit on a nupower cordless drill at?
danny_murray
  • 55 Answers
SOURCE: porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Posted on Dec 05, 2008
  • 1214 Answers
SOURCE: how to change drill bit
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Posted on Jan 28, 2009
  • 142 Answers
SOURCE: locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
Posted on Jul 06, 2009
tcraignfam
  • 30 Answers
SOURCE: DeWalt cordless drill DW926. I can't get the
Turn your drill speed selector to "1" and put drill direction in reverse. Hold the outer end of the chuck and push the trigger. Should come loose.
Posted on Dec 12, 2009
Testimonial: "Perfect - thank you!"
SOURCE: I am looking for a 18v charger for a NuPower
I have one, no idea what is it worth I have a battery too.
Posted on May 12, 2010
How to release a bit stuck on the 18 volt cordless hammer drill???
Put the clockwise - anticlockwise button to the middle 'lock' position. That is the button above the trigger that is orange. Then viewing the drill from the drill bit, turn the chuck anticlockwise.
Dec 12, 2017 | Hammer Drills
Looking for batteries for a Nupower cordless drill. model NPCD24. can anyone help please !
If I had a cordless drill that took hard-to-find batteries, I would take or send my existing battery to a battery rebuilder. They're easy to find on eBay, very inexpensive, and I've had good luck with them. If you can't get along without a drill while you wait for the battery rebuild, Harbor Freight can supply a temporary substitute inexpensively. Of course, by the time you go through all of the above, you could have gotten a DeWalt or Makita, which have easy-to-find batteries, for not much more moolah.
Sep 18, 2017 | Drills
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
I can't get the drill bit out of My Makita 6333D cordless hand drill. I usually have no problem. I did tighten the chuck pretty tight, but now can't loosen it. Help.
put the drill in a vise and using a pair of channel lock pliers grip the chuck and it should come loose will a little tug on the pliers
Sep 12, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Can you give me step by step on how to change drill bits on the Mastercraft Souce One 18V Cordless Drill.
pull the collar on the front forward and insert hex end of bit in and let collar go back. this locks the bit in.
Aug 29, 2010 | Bosch PS20 2 Factory Reconditioned 10.8V...
Drill chuck stok in the thigt possition cant get the bit out ; cant make de chuck to open or close
Sometimes this happens when you have a drill bit that slip. Take a pair of channel lock pliers, and try and turn the chuck counter clockwise. Do it sharply so the drill doesn't turn. IF that still doesn't work put the drill in reverse and try the channel locks again
Jul 05, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I loosend the drill bit on my Makita cordless drill to much and now it's stuck. I can't loosen it to tighten
That can be cured with WD-40, and 2 pairs of channel lock pliers. Spray the chuck inside with WD-40, then grab the lock collar closest to the drill body itself with the pliers, being careful not to squeeze too hard and damage the plastic, then do the same for the spinner in front of it and rotate it clockwise while holding the lock collar in place.
Mar 24, 2010 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Jaws of my Hitachi 18V cordless drill are locked shut
Other than two quick squirts of WD40 and nice new chuck key?
Apr 07, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
