Question about Crosley CDG6000 Gas Dryer
Dryer wont dry unless i work the heat selector side to side before starting
  • Mark Nichols May 11, 2010
    hmm, very odd what is the model number?
The exhaust was clogged with lint from the lint filter to the blower and the pipes. Cleaned everything out and works fine now.
Posted on Jun 24, 2009
My dryer works on high heat on the timed side of the knob, but won't work on the low heat and high heat (more dry, less dry or energy preferred setting)
Does this mean the timer wont move or it will not dry ? if it will not dry it is more than likely the timer , if it wont advance then you have a shorted element
Nov 03, 2015 | Dryers
The dryer wont heat-it over 5 hrs to dry a load. it would not turn off on automatic side & just keeps running. it turned off on the timed side
If it's not making heat the humidity sensor will never dry out, therefore it keeps running. It sounds like your heating element is bad.
Jan 20, 2014 | Whirlpool GGW9200L Gas Dryer
Tumble dryer wont dry clothes reset button doesnt work
Check the Circuit Breaker. It is a double Breaker Switch. one side is for the heat one for the motor. If that is good then it's possibly the Heating Element or one of the two heat sensors.
Jan 17, 2013 | Dryers
What is the heat selector knob?
This allows you to adjust the temperature to match what you are drying. Some fabrics and clothes require low heat or you may only be drying a small amount of clothes and don't need much heat. You also may not want high heat to avoid shrinkage of some clothes.
Jul 16, 2012 | Avanti D110 Electric Portable Dryer
Whrilpool dryer wont start set selector press start and all lights blink and dryer makes clicking nosie from apprears bottom rear
Sounds like something you will need a repair man for.Unless you are mechanically inclined it sounds like it's electrical.
Oct 20, 2009 | Whirlpool GEW9250 Electric Dryer
Frigidaire dryer error E4A dryer will run for about 45 seconds then shutoff and start beeping and showing the above error code
This is this is the "program Timeout Fault". Meaning the drying time has exceeded program time for that cycle.Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, or bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 08, 2009 | Frigidaire Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat
ok so you have some heat.your dryer unless an ge one has one element so if you have heat its working.then what you have is an exust problem.once you heat up the clothes and cause the moisture to evaporate then it must be able to leave the dryer or it reclings to the clothes,hence lond dry times.to test this dry a load with the venting undone and the dryer pulled out.dont worry it wont start a fire/never!its about 180 degress to 130 of moist air. if ok then confirms that venting is blocked.some times dryers get blocked internaly also but do the other first.God bless,tom
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
Dryer spins but wont heat - element okay
HAVE YOU CHECKED THE MAIN FUSE FOR THE DRYER?WHITE AROUND THE SIDES AND DARK IN MIDDLE,UNSCREW THE KNOB COUNTER CLOCK WISE TO REMOVE KNOB,SHOULD BE 2 SCREWS HOLDING TIMER REMOVE THEM AND THE PANEL SIDE SCREWS,THANKS-MIKE
May 29, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Crosley CDG6000 Gas Dryer Logo
89 people viewed this question
Top Crosley Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
jasbo
jasbo
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
