Question about Cooktops
I have an electrolux ehl8740fok its an ex display had it installed but it comes up with e9 can you help me please thanks
Power went out. reset circuit breaker and all the lights keep flashing 8.8 and won't stop
Hello Heidi, thank you for your post!
From my understanding your Electrolux cooktop is displaying an error code of 8.8. The error code of 8.8 means there is a shift register issue on the middle touch board. This could a possible issue with the control board or the middle touch board. You may need to have a professional technician out to your home for proper diagnosis. We hope this information is helpful to your repair. -Matt
Jan 23, 2016 | Electrolux 36"" Induction Cooktop
E9 being displayed despite using induction kadhai
Try resetting the unit by turning your circuit breaker off and back on.
Dec 01, 2015 | Cooktops
Electrolux Cooktop Hybrid error E07- sometimes, cooking gets interrupted with E07 code and shuts off the panel. On next turn on, usually works okay. Could you describe me the error code? Thanks!
I appreciate your post, friend!
I see that you are having an issue with your Electrolux cooktop displaying a "E07" and shutting off. An "E07" code stands for an issue with your key sensor timer and this could be a potential problem with your right, left, or center board. This may not be a simple DIY job and I would highly recommend having a professional technician come out to diagnosis your cooktop. The technician will have the appropriate tools needed for properly diagnosing your cooktop. This step will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Feb 19, 2015 | Electrolux Cooktops
Stove top error code E 15
Thank you for your post, friend!
From my understanding your Electrolux range is displaying an error code of "E15". An "E15" code stands for the ESEC self-test failed. This might be an issue with your ESEC (Electronic Surface Element Control) board or ESEC-UIB (User Interface Board). Before seeking any assistance with a professional technician I would advise you to perform a reset on your range. You can perform a reset by disconnecting power from your range for roughly ten minutes. If that does not help resolve your current issue I would suggest consulting with a technician for repairs. Hopefully this information is helpful. -Matt
Feb 15, 2015 | Electrolux Cooktops
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
Electralux Surface Cooktop, with code---E----40
Hi Linda Wallman, thanks for your post!
I see that your Electrolux cooktop is displaying an "E40" error code. Typically, the "E40" stands for no communications, shorted bus. This could be an internal communication error with your left control board, relay board, or filter board. I would recommend getting a technician out to your home for proper diagnosis and repair. I hope this is helpful. -Matt
Oct 20, 2014 | Electrolux Cooktops
Electrolux e21
I understand that your Electrolux cooktop is flashing an "E21" error code. Based off the information I was able to look up it sounds like a possible issue within the left board. I would suggest seeking assistance from a technician for proper repair because some of these intricate parts do require precision and patience. Therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. -Matt
Sep 28, 2014 | Electrolux 30" Induction Cooktop
Error code 32
Same unit, error 32. Replaced capacitors that were bulging on relay board. Work for a bit now same error message. Read somewhere else that they capacitors on filter board likely went as well. Where is the filter board located? I am guessing under the induction elements because I can't imagine it would be anywhere else. Can someone please assist in telling me how to access that board? I would greatly appreciate it
Dec 21, 2013 | Electrolux Cooktops
Our Electrolux cooktop that we just installed started making a beeping noise and all of the lights were flashing! We turned the breaker off and let it sit and turned it back on thinking that would help and...
Hello Lisa, thank you for your post. I understand you have already tried resetting the cook-top by unplugging it. However, it is important to wait approximately ten minutes and then turn the unit on.
If the beeping continues, it could possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. Since your unit is in warranty, you can often locate a qualified technician on the manufacturer website.
Thanks for allowing me to the opportunity to assist you!
Aug 18, 2013 | Electrolux 36" Electric Hybrid Induction...
Electrolux insight cooker EKT6045 problem with hob controls
i have an electrolux model ekt 6045 it does not stay on it comes on for 1sec then goes off wot would be the cours of this please the oven stays on but the hob doesent thank you.
Aug 11, 2009 | Electrolux Cooktops
Cooktops Logo
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
