Question about Digi home DG250DTRA08
Readout just says fail - Digi home DG250DTRA08
If the transmission in a 1998 Toyota Camry is failingwill that cause the motor to misfire
Generally no, it will not. A failing trans will cause bad shifting, hard shifting, slippage in gear, but not misfiring. Get a readout from your ECU to see if any trouble codes are held.
Apr 01, 2015 | 1998 Toyota Camry
Treadclimber centering
Dear Sir:
ecalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the TreadClimber by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 15, 2012 | Exercise & Fitness
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
System works fine, plays well etc. However, the digital readout is no longer visible. Ideas?
There is typically a dimming feature among these types of systems. There may be a button on your remote/system panel to adjust how dimmed the display through which you can adjust it. If not, then try to enter the system setup mode and adjust the brightness of the display.
OR if the digital readout is not very dim and is in fact blank then your LCD panel has failed. You should replace the panel or get a new receiver. I would start by calling the customer support line as this will surely be under the manufacturer's warranty.
please rate my solution
Jul 31, 2010 | Bose Lifestyle 25 System
No readout on front panel. UVW-1800
No front panel readout on a UVW-1800 is caused by the audio bargraph display failing. This display has an auxiliary power supply in it that provides power to the front panel display.
Oct 15, 2009 | Sony Televison & Video
PELOUZE 4010 SCALE READOUT FAILED
my pelouse when i turn it on it stays on 0.0 when i put weight on it stays on 0.0 it then goes of i need help to get it to work
Jan 28, 2009 | Office Equipment & Supplies
Whirlpool Wall Oven sometimes power fails in middle of a baking session. Display goes blank and oven will not work for 10-20 minutes. Then oven will come back on with a PF readout.
Could be several things; 1. Electrical connections in oven are loose. 2.The circuit breaker for the oven could be failing. 3. The electronic control is failing. Make sure when oven is operating, the cooling fan is operating. If the cooling fan is not working, the electronic control will overheat and shut down.
Jun 01, 2008 | Whirlpool Kitchen Ranges
Screen Readout
yes screen readout is bad... u need a new screen
May 01, 2008 | SanDisk Sansa E280 MP3 Player
Display stopped working
My Alpine CDA-7842 works fine from a functional point of view but the display (readout) had stopped working. All the lights on the display work but the actual readout is blank. At first the readout would intermittently work now it's completely dead. Any assistance would be greatly appreciated.
thanks
Oct 26, 2006 | Alpine CDA-7842
Digi home DG250DTRA08 Logo
32 people viewed this question
Top Digi Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
