Question about Garden
How much Roundup concentrate does it take for a gallon of water?
5 Suggested Answers
  • 308 Answers
SOURCE: HOW MUCH ROUNDUP TO GALLON OF WATER
regular concentrate 6 fl. oz per gallon
super concentrate 2.5 fl oz per gallon
Posted on Jul 20, 2009
heatman101
  • 43501 Answers
SOURCE: How much Roundup weed and
50-1 or about 2.8 ounces per gallon of water is the recommended mixture...
heatman101
Posted on Sep 18, 2010
  • 56 Answers
SOURCE: I have Roundup with no instrutions. 1 litre,
For general use I use 3 ounces of herbicide per gallon of water. For best results spray on a calm warm morning.
Posted on May 07, 2011
eugbug
  • 479 Answers
SOURCE: I have a bottle of concentrated "Roundup", but
Roundup concentrate is normally mixed at the rate of 1 to 50 or 2%. This should kill most weeds and you can treat hard to kill weeds with a second application. 2% works out at about 3 fluid ounces per gallon. For an imperial or UK gallon you would need 90mL or 75 mL in a US gallon. You will probably find a bottle or can around the house which has this capacity and cut the top off it to use as a measure.
Posted on Jul 18, 2011
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Apr 24, 2011 | Roundup "" Weed & Grass Killer
How much roundup do i put in 3 liters of water
Round up is currently offered in a few variations. If you have the "Spray and GO" or the "Spray and Go" refill product do not add water. The ratio is already correct. Likewise for the "Redy-to-Use Plus", do not add water.
If you have the "Weed and Grass Killer Concentrate Plus", the ratio is 3oz/gallon water. 3 liters of water=0.79 gallons so use 2.4 oz of this type of Round Up.
If you have the "Weed and Grass Killer Super Concentrate", the ratio is 1.5oz/gallon water so you would use 1.2 oz of product mixed into 3 liters of water.
If you have a different product and just need to work out the conversion from gallons to liters, 1 gallon=3.78 liters.
Hope this helps.
Dec 31, 2010 | Roundup "" Weed & Grass Killer
How much Roundup do you mix in one gallon of water?
If you have the concentrate (label reads Concentrate Plus), the amount of Roundup will depend on the plants you want to kill. Use 6 fl oz (12 tablespoons) for 1 gallon for most plants. If you have seedlings or easy to kill weeds, use 3 fl oz (6 tablespoons) per gallon.
The Super Concentrate may have a different rate. The labels are usually on the manufacturer's web site as PDFs.
I hope this helps.
Jul 05, 2010 | Roundup "" Weed & Grass Killer
How much roundup to 1 gal water forwatering can use
6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 29, 2010 | Roundup ScottsRoundUp 0394560 PT...
Need to know how to mix round up and water
Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 27, 2010 | Roundup "" Weed & Grass Killer
How do i mix roundup concentrate plus
Roundup Concentrate Plus is the least concentrated mixable product Monsanto offers. Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 25, 2010 | Roundup ScottsRoundUp 0394560 PT...
Quantity of Roundup weed killer to spray 140 acreas of crop land
This 2.0% glyphosate is ready to apply at a rate of 3-10 gallons per acre That's 420-1400 gallons per 140 acres. Some weeds need a higher concentration than 2%. Most farmers buy 41% glyphosate concentrate, determine the number gallons of spray mixture their equipment will deliver, determine the concentration of glyphosate they need and mix the concentrate with water accordingly.
Apr 01, 2010 | Roundup "" Weed & Grass Killer
How much roundup to 5L of water so I can spray
If you're using pro-roundup or agriculture level roundup mix 1 Cup of roundup to 5 gallons of water. This will give you a mixture between 1% and 2% which will kill most undesirables and anything else that picks up the spray.
Jan 21, 2010 | Roundup "" Weed & Grass Killer
May 22, 2009 | Roundup "" Weed & Grass Killer
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
