Question about GE AJCQ08ACB Air Conditioner
A/C blows warm air
Have a Trane 19i dual compressor system with 10 year service through Home Depot. Both compressors were out the electronics at the condensor fried and the coil leaked at 5 years. All of that was replaced a week ago and now my a/c blows strong but warm air. I'm looking at a sixthe service call over a month and hope they can fix it.
The condensate line was filling and the kill switch was turning off the compressors but the blower is not tied in so it kept running. When the water pump caught up it would take five minutes to turn back on and the temperature was roller coastering. They disconnected the kill switch. now I'm watching to see where the condensate will go if the pump can't keep up. I'm not sure for the long term if this is the best solution.
Posted on Jun 25, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
My air conditioner is blowing warm air on the driver side and cold on the passenger side
see this steps and think with clearly and logically NOT feared. God bless you
checkmark.gif Start with the compressor. Does it engage when you turn on the A/C?
If so, the compressor is working and the A/C system probably contains enough refrigerant to make cold air, so the problem is inside the HVAC unit. Replace the motor that controls the blend air door (this is a difficult job and best left to a professional since it involves tearing apart the HVAC unit -- about an 8 to 10 hour job!).
If the compressor does not engage when you turn on the A/C, see if it will run by jumping the compressor clutch wire directly to the battery (use a fused jumper wire). If the compressor works when you jump it, and the A/C blows cold air, the system contains refrigerant and the fault is likely a bad A/C compressor clutch relay or a bad clutch cycling switch or pressure switch.
If the compressor does not engage when you jump it, the problem is a bad compressor clutch.
If the clutch engages but the compressor does not turn (the belt will start to slip and squeal), the compressor is locked up and you need a new compressor.
If the compressor clutch engages and turns the compressor, but the A/C still does not blow cold air, the system is probably low on refrigerant and needs to be recharged.
Jul 24, 2012 | 2007 GMC Sierra Classic
The Cool mode wont cool. It's just like fan mode. I cleaned all the dust off the panels and still wont blow cool air.
First the weather is extremely hot mid 90's and humid.I have a Trane combination a/c heat pump system. The A/C was pumping out warm air.I called for a technician and the problem was the compressor was not working.The solution/fix was to replace compressor start capacitor.The technician was here for about an hour.The compressor was running before he left however I informed him the air coming out of the a/c ducts after one hour of run time did not feel as cool as usual. It took from 1pm until 10 pm at night to cool the house air down to 80 degrees and the system ran constantly.I left it on 80 as that is where I usually leave it. Today again it is running all day barely able to keep the house at 80.My home was built in 07 block house, well insulated with thermal double pane insulated windows.I suggested to the tech to check the refrigerant level but he did not think it necessary and did not perform the check while here. The unit will cool the house down to 80 degrees but runs constantly.My question is: Should I have a technician come check out the system to insure proper refrigerant levels and pressure????????
Jul 30, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
I have a trane xe 800 its blowing air but not cold air, i felt the copper/bronze tube running into the unit it is luke warm also no chill at all. where should i start checking to get my house cold again.
Hello, if the pipe with insulation is luke warm then either the unit is empty of refrigerant due to leak or the compressor is not running at all. Start by going tje the outdoor unitnand checking if the compressor is running, if it is then the unit has no refrigerant, if the compressor is not running then either a bad capaitor orbthe compressor itself might be bad.
Jul 20, 2011 | Heating & Cooling
My fujitsu split system blows warm air after about
There is not really enough information here to properly answer your question. I can make a couple of observations for you though. 1. Compressor, yes this could be the problem, but it is not quite that simple. Is the compressor running when the hot air starts to blow? 2. Capacitor, no I don't believe this is the problem, as if it were a capacitor problem, chances are the unit wouldn't even start. 3. Gas leak, again no, if it were a gas leak, then you wouldn't get an hour of good run time when the unit starts up, repeatedly. Hope this helps.
May 07, 2010 | Heating & Cooling
AC blows hot air but AC compressor works
if the compressor works and your freon is charged it may be the blower flapper door....disconnect battery for 10 minutes and then re-connect to reset the electronics that control the flapper
Jan 12, 2010 | 2001 Mercury Sable
Compressor not working
sounds to me like the compressor may be grounded, but i would check to see if there are any burn marks where he did his work. The compressor has an internal overload protection that opens and closes but may have failed. It is hard to tell what happened from here and who is to blame. A compressor can fail then end up blowing up afterwards though
Jul 18, 2009 | Heating & Cooling
Ac blow warm air
need to have a set of gauges on it and read the low side and high side to see if pump is weak that year compressor i think is on the bottom passenger side ,it is not a good desigh pump may be weak
Jun 29, 2009 | 2002 GMC Yukon Denali
GE AJCQ08ACB Air Conditioner Logo
189 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
