Question about Cell Phones
How to record a message on the Eurotel Elite 2825 Single Digital Cordless Phone + Answering Machine manual
  • 3 Answers
SOURCE: don't have instructions to record my message on the digital answering machine
I believe you use the "memo rec" In the silver color on the base, second line of buttons on far left.
Posted on Apr 20, 2009
  • 4 Answers
SOURCE: Where can I get a
try http://www.binatonetelecom.com the manual for the Activity 2610 looks similar to the e1110 manual.
link
http://www.binatonetelecom.com/resources/0000/0271/Activity_2600__2610_.pdf
Posted on Aug 19, 2010
  • 3278 Answers
SOURCE: I have a 5.8 GHz
Hello.
Try resetting (disconnect and reconnect the power) the modem/router to your system.
Then, if necessary, reset (again, disconnect and reconnect the power) your handsets.
Hope this helps.
Posted on Nov 02, 2010
  • 1416 Answers
SOURCE: KXTGA931T cordless phone.Answering machine wont
hello,
Here are two step by step instructions on how to make use of the Panasonic recoding device below.
Your Panasonic cordless phone system comes with an answering machine that is designed to record messages. Set up your answering machine to your personal preferences so that you can collect messages while you are away from home. Once your answering machine is set up it will work in exactly the way that you prefer it to and you can listen to your messages and return phone calls whenever you get home from work or play.
Instructions for the first step.
  1. Press "Getting Rec" on the base unit.
  2. Press "Getting Rec" again within 10 seconds after you hear the pre-recorded message, "To record greeting, press record again."
  3. Lean in so you are within eight inches of the microphone on the unit, and wait for the long beep.
  4. Record a personal greeting lasting up to two minutes after you hear the beep.
  5. Press "Rec Greeting" or "Stop" after you have finished recording your greeting.
  6. Record your greeting again if the base unit displays an "E" and beeps six times in a row.
  7. Press "Greeting Check" to hear the greeting you recorded
  8. Instructions for the second step
    1. Press the "Greeting Check" button on the base of your Panasonic phone to listen to the current greeting. If the current greeting is satisfactory, you can leave it.
    2. Press the "Greeting rec" button on the base of your Panasonic phone and listen for a beep. Speak clearly and record a short greeting. Press the "Greeting rec" button when you finish recording the message.
    3. Check your recorded message by pressing the "Greeting Check" button. If you like the new recorded message you are all set. If not, repeat the steps until you get a message you like.
    4. Adjust the volume of the answering machine on your Panasonic phone. Press the "up" arrow to turn the volume up and press the "down" arrow to turn the volume down. This is designed to enhance your message listening experience.
    5. Pick the number of rings that you want the phone to emit before the answering machine picks up. The factory setting is four rings. Press "Menu" and press the up or down button until you reach "Initial Settings." Press "Select" at "Set Answering." Press "Number of rings." Use the up or down keys to select the number of rings and then hit the "Select" button.
    6. Press the answering machine's "Play" button to listen to your messages. A number will appear on the base of the phone to represent the number of messages you have. Press "Delete" to remove your messages from your Panasonic phone's answering system.Hope this help?.Thanks for using fixya.
Posted on Nov 19, 2010
vanherringto
  • 1738 Answers
SOURCE: Hi I've been trying to
Thanks for visiting FixYa!
Although you refer to the model number of your phone as a Dect 6.0 43-260 I've only been able to locate the instructions for a Dect 6.0 43-259. Hopefully, they are close enough.
This is a link to the Quick Start guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4300259_QS_EN.pdf
This is the link to the User Guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4300259_PM_EN.pdf
The User Guide explains how to record your own personal greeting as follows:
(See Page 50, Recording a Personal Greeting)
Your answering system comes with a pre-recorded outgoing message or
greeting that plays when you receive a call: "Hello, no one is available to take
your call. Please leave a message after the tone." You can record your own
personal outgoing greeting. Your recorded greeting must be between two
seconds and thirty seconds long.
1. On the base, press MENU/SELECT.
2. Select the ANS. SETUP menu, and then the RECORD GREETING sub-menu.
3. RECORD GREETING, START [SELECT] appears. Press MENU/SELECT
to start the recording. Begin recording after the announcement.
The message counter on the base LCD displays "30", and then begins
to count down.
4. When you finish recording, press MENU/SELECT again or press (key and LED (play/stop) . You
will hear a confirmation tone, and your recorded greeting plays back for you.
I hope this helps.
Posted on Feb 25, 2011
Given this phone without manual. is it registered under Binatone?
google the make/model/manual and see it you find one to download .
Mar 16, 2015 | Lands Phones
Binatone phones manual
i have the eurotel (Binatone )E1110 manual which may help I could e mail it to you if you wanted
Aug 18, 2014 | Binatone Telecom Style 1810 Cordless Phone...
Eurotel 2825
Sorry, lost my manual and forgotten how to re record answer phone message. Any help appreciated...Thank you
Jan 02, 2014 | Lands Phones
I need Manual for Eurotel Elite 2825 Triple Digital Phone
I need Eurotel Elite 2825 Twin Digital Phone user guide
Dec 06, 2012 | Lands Phones
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Cell Phones Logo
115 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
