Question about Brother XR7700
How do I fix the dogs when they won't feed the fabric?
I hope this makes sense. I took the plates off to clean my machine, and when I put them back on it wasn't feeding anymore. I noticed the lever to change the height is not activating a change as well. My husband and I have both looked at it, but no luck. We thought he fixed the lever issue, but when I tried to use it again, the dogs wouldn't feed. They are raise, just not feeding. The lever is not raising and lowering correctly. How do I fix it?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Brother Expert
  • 300 Answers
The feed dogs on that machine (and many others) do not go back up when you move the feed dog drop button to up; they return to the up (feeding) position after the machine makes a stitch or two. So if they won't come back up after you tinkered with them, you will now need to bring it in for servicing.
Posted on May 14, 2014
bargainbox
  • 1388 Answers
SOURCE: The feed dogs stick and bunch up the fabric and pull it out of the hoop.
I would take it back to the repair shop with some of your samples and the "mess" in place so they can sort it out for you.......after all, you have paid them to do a service and should have a 30 or 90 day warrantee implicit in that arrangement.
I suggest you phone first to arrange to meet (with the tech too if possible) and outline your concerns, they do have a responsibility to you.
Whenever this happens to me (rare thankfully) I give the machine priority and generally talk it through with the customer and try a sew test with them present so we can see what is happening then and there.
I would not advise you to "play around" inside as it will void any warrantee.
www.bargainbox.com.au
Posted on Apr 14, 2008
bargainbox
  • 1388 Answers
SOURCE: Feed dog & auto threader problems.
Remove the needle plate and clean the lint from between the teeth of feeddogs, also around and inside bobbin case.
The switch for the feeddogs is to raise (normal sewing) or lower (free motion) and if there is no difference, the accumulated lint will have made a felt pad between the teeth forcing the feeddogs to stay down and present with the problem you describe.
When things go a little "weird", the common instinct is OIL EVERYTHING............DON'T DO IT !!! ....this is rarely the solution on its own account, and can make the servicing a great deal longer as the excess must be removed........little oil regularly, not a bucketful every 5 years is a better approach.
Posted on Jun 09, 2008
bargainbox
  • 1388 Answers
SOURCE: feed dog wont feed the fabric
Remove the needleplate and clean between the teeth of the feeddogs.
Ensure the feeddogs are not lowered for free motion sewing.
Don't know the make/model to be any more specific, so post back here or to the Contact Us page at  www.bargainbox.com.au if there is more to do.
Posted on Nov 24, 2008
  • 152 Answers
SOURCE: my feed dogs will not come up into position
Some machines have to take a stitch for the mechanism to "pop" back into place, I don't really know if your brother is like that but try to sew with it and see if they click back into place.
Posted on Oct 23, 2009
  • 11800 Answers
SOURCE: I have a brother CS6000.
The lever/button is simply a mechanical arm attached/sliding into the frame on one side and the other on the foot of the feed dog with screws or pins - they must allow the lever to rotate and slide a little. It should be firmly attached - no wobbles - and the movement between positions should be firm - a spring is used to lock it in position (up and down).
If it's wobbly and it moves easily without snapping in position then the mechanism is broken - you must open the back and see if the feet and the securing spring are still attached to the command lever/button. If not then you must reinsert the pin and find out why it has slipped out.
Posted on May 02, 2011
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
I have been sewing all morning. Suddenly the fabric does not feed everything is clean
Look at the feed dogs to see if they are rising above the needle plate at least 1 mm. If not rising lint may have felted between the feed dogs and the needle plate. It could also be the feed dogs have been lowered, or the height has slipped. If the feed dogs are above the needle plate turn the hand wheel and see if they are moving from the front of the machine to the back. If not it is a length adjustment. If this is normal the pressure on the fabric may be too low. Another problem may be the timing of the feed dogs. The feed dogs should rise above the needle plate when the needle leaves the fabric and descend when the needle comes down into the fabric. This requires an expert to fix.
Mar 15, 2014 | Euro-Pro Shark 60 - 384
Feeder dog is in reverse and thread won't feed through bobbin..
it would really be a good idea to have the machine serviced at a sewing
machine shop
May 05, 2012 | Sewing Machines
O.comI'm having a couple of problems: it seems like the feed dogs need to be adjusted because I need to gently pull the fabric through, from the back, otherwise the fabric won't advance & I...
if you have a manual check where your feed dog knob is, push the knob in the opposite direction,,if that doesn't help then something may be wrong with the feed dogs,,you should be able to see the feed dogs in the needle plate area & to feel them with your fingers.
you may need to have the machine serviced at a sewing shop
Sep 21, 2011 | White Sewing 1730 Mechanical Sewing...
I cleaned my machine, but after putting the plate back on, the feed dogs don't pull the fabric through now.
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
Sep 07, 2011 | Brother CS6000i Computerized Sewing...
Feed Dog problem
Here are some common reasons that the fabric won't feed:
1. Stitch length is set to zero, or machine is in button hole setting
2. Feed dogs are dropped (free motion setting)
3. Broken gears (typically in old singers)
4. Presser bar not coming down - may be bound up.
5. Lots of lint under the needle plate (in between the feed dogs) preventing feed dogs from raising.
Hope this helps.
Nov 29, 2008 | Baby Lock Esante
Feed dog wont feed the fabric
Nov 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Feed Dogs won't feed fabric.
I can not find the screw. does anyone have a picture of where the screw is?
Nov 05, 2007 | Sewing Machines
Brother XR7700 Logo
108 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
