Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
How to turn on shower 3175 - Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
2 Suggested Answers
hessmar
  • 5 Answers
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
Very difficult to pull faucet handle out to turn on in shower installation
the cartridge heeds to be replaced. It sounds like you have a moen shower valve. turning the stem on this cartridge will only reverse hot and cold. it will not fix your problem.
Sep 01, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Turning on hot or cold water I get a loud screeching noise and very low pressure. If I keep turning the handle, I can get rid of the noise, but still low pressure.
It sound like you have sediment blocking your valve, faucet airiator or shower head (depending on what you're using). FYI: if it turns out to be defective all Moen faucets and showers have a life time warantee.
Jun 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
What could be causing a high pitched screeching sound when I turn on my single handle shower?
If you haven't turned the main back on, this could cause the sound.
Re supply the water to the lines.
May 10, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Shower head and bathtub faucet both running when showering
Sounds like diverter valve which is your shower handle valve is bad take it apart and check out and replace it if possible because that transfer water to shower head.
May 01, 2010 | Moen 3175 Legend One Handle Shower Faucet...
We have two 16 year old shower faucets (house was built in 1993 by Del Webb). Can't tell what model they are. We are guessing they are Moen Legend 3175 (one handle). Problem seems to be pressure balancing...
This is a common problem with this type of shower mixer valve. They are not very good at regulating with pressure change. Your options are somewhat limited to not flushing the toilet or using any other taps when in use, repalce the mixer valve for a modern ceramic unit or installing a 2 vane hot & cold shower pump.
Nov 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Only hot water/ little pressure
You must of turned off your water to the house or maybe it was turn off in the street recently because it sounds as if you have debris in you strainer remove the head and rise of removing any dirt rise out both front and back of shower head while head is off run shower to make sure you are getting full pressure out of the pipe that the head is connected to
Jul 11, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot water dribbles thru shower head when turned to hot
Nov 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
47 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
