Question about Oregon Scientific BAR208HGA Advanced Weather Station with Atomic Time
Main unit screen is blank - Oregon Scientific BAR208HGA Advanced Weather Station with Atomic Time
What to do when an 8022c wall thermostat screen goes blank - no numbers, just the lines dividing the three areas? Pushing reset does nothing.
Pop the cover off and check the battery. Replace if necessary. If it still doesn't work trip the main breaker for the ac unit off wait 1 minute and turn back on. If it still does not work then you have a more technical proble. Could be a bad thermostat or control board in the ac unit.
Jul 03, 2016 | Audio Players & Recorders
No display blank screen
hi sir. the problem is the flex wire of the display on the handset unit and this is common. you have 2 solutions. first change for a new the handset unit. or open the handset, remove the main board, separate slowly the display screen from the main unit. whit a hot air gun, give some hot to the white flex on the main board side(not too much or you can destroy that). and tighten a little with your fingers on the flex and the main board. This should paste the flex.
Nov 09, 2013 | Panasonic KX-TG5631 Cordless Phone
Error 03 is displayed
Error 3 means that the unit cannot power on and control the air pump -the unit itself is faulty. The screen is totally blank that means that the control processor in the main unit had malfunctioned.
You cannot fix the defective unit. Time to replace a new unit.
Jul 26, 2011 | Lumiscope 1092 Wrist Blood Pressure...
Compaq blank screen
I specialize in repairing these particular compaq units and they all have the most terrible quality just being thrown together, but if someone took the time to inspect everything inside the computer and make sure it was properly connected and organized and functional then there would be no problems. Therefore I get like 3 of these computers a month.
Apr 27, 2009 | Compaq Presario SR1703WM PC Desktop
My ps3 turns on but nothing comes up just blank screen if i hold the power button on the front for 5 sec the screen will flash and then blank screen
to reset the video settings you have to turn the main switch on the back of the ps3 then place your finger in the on sensor in front of the unit with your finger there turn the main power switch on the back of the unit the playstation turns on keep your finger there until you heard one bip and then remove your finger from the on sensor before the unit turns off if you keep your finger there for too long it will shuft off the unit so remove your finger once you heard the first bip and wait about 40 to 50 seconds some playstations take that long to restart after resetting the video card if this do no work try few times but if still not working then your graphics card is bad and sorry it can't be replaced
Mar 12, 2009 | Sony Playstation 3 (PS3) Console
Blank screen
you need to check the screen voltages inside the unit is a sticker with the voltages on it, if all the voltages are normal, could be the panel is bad, if the voltages are low or nonexistant it could be the L-main,Main or Y-main board
Dec 02, 2007 | Akai PDP4290 42 in. EDTV-Ready Plasma...
AKAI PDP4290
Oct 13, 2006 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Oregon Scientific BAR208HGA Advanced Weather Station with Atomic Time Logo
32 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
