Question about Braun 3728 ProfessionalCare 8000 Series Electric Toothbrush Replacemen
Replacement battery? It doesn't hold a charge more than a day.
Nokia lumia 800 won't hold charge
First you would need to check the connectors on the charge cable and if its still not charging, then do a hard reset which means totally power the device down and then power it up and then try and charge again. Your charging cable might be defective. You can remove the battery go to bottom of device, remove memory card, then use a small screwdriver. But I would first try the first two steps because removing the battery on this device would require you to dissemble the whole device
Jul 28, 2013 | Cell Phones
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
The car was running fine one day then the next day it would not start. We tried jumping it thinking the battery might be dead and it still would niot start. The car has power until we take the jumper...
Sounds like you have a toasted battery or alternator. Have you performed a load test on the battery? Have you tried to charge the battery? First remove the battery and charge it externally from the vehicle. If the battery won't hold a charge, or won't hold a charge of 12 volts, replace it. Once you have the vehicle started, test the operation of the alternator. It should be putting out at least 13 volts back to the battery to keep it charged - if it is putting less than 13 volts or more than 16 volts, replace the alternator.
Nov 01, 2011 | 2005 Chevrolet Malibu
My 85 maxim will start if u push it and continue to start the rest of the day but once it cools down you will have to push it again any ideas
Sounds like you battery isn't holding charge overnight. If it was the alternator, it wouldn't start during the day so the alternator sounds fine.
Make sure the battery that is on it is the right one for the bike.
Try taking the battery off the bike and using a battery charger to charge it overnight. If that doesn't work, I'm afraid it's going to need a new battery.
Good Luck
Jun 26, 2011 | 1985 Yamaha XJ 700 X Maxim
I have a 92 camaro rs tbi and the alternator and the battery went bad and i just replaced them 2 days ago and now the battery is dead again and after i charge the battery it still wont hold a charge the...
take it back they have to replace it,they either have a 60-90 day warrenty also see if battery cables are tight.if you have a chrger see if battery holds a charge.
Aug 29, 2010 | Chevrolet Camaro Cars & Trucks
Braun 3728 ProfessionalCare 8000 Series Electric Toothbrush Replacemen Logo
101 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
