Bostitch electric stapler e66760 support
My new E66760 electric stapler shoots the staples through the paper making it useless right now. Is there an adjustment to back that off?
How do I reload staples into a Bostich Electric Stapler E66760? I tried standard staples and they won't seem to fit
RTM. Read the manual. If you didn't keep it, you can Google for one with your make, model and manual in the search box and you should be able to get a .pdf file of the manual which you can save to your computer. You're probably using the wrong size staples.
Mar 05, 2015 | Staples Office Equipment & Supplies
My Bostitch 20Suite office stapler won't staple and isn't jammed
Hello, Go to this website for instruction manual download. It also will have a number u can call for tech support to talk to a person, if further help is needed. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Jun 04, 2014 | Stanley Bostitch 20SUITEBLK Heavy Duty...
Bostitch electric stapler wont open
Hello, Go to this website for support number and downloading of the operators manual for the model of stapler. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
May 01, 2014 | Stanley Bostitch B8 Electric Stapler
When I push the button it will not open to let me add staples
Hello, Go to this website for support phone numbers and a place to download operator/trouble shooting manuals. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Apr 25, 2014 | Stanley Bostitch 02210 Electric Stapler...
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
Have a Electric Stapler B8E E66760. Won't kick out to load staples
pretty simple. Take off the plastic cover, at the front where it staples will be a black metal piece on top of the stapling area. That is the front clip release. Release the staple tray like you would normally with the button and also Push the top black piece back to detach it from the staple tray. It should spring out then. Clean around it with alcohol and keep the cover off. Push it back in place, release it a few more times to make sure it works correctly now, then put the screws back in.
Oct 04, 2010 | Office Equipment & Supplies
Stanley-bostitch B8E E66760 jammed and can not un jam it
i pushed down on the on the cartridge itself and then on the release button. it freed the cartridge and i was able to access the staples themselves. (the tray was full of new staples).
i replaced the cartridge empty, activated the stapler a few times...reopened the tray, reloaded it with the same staples i had removed, and it worked fine.
i found this useless information at the bostitch website:
http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-7781364541754123555/view_question!PAGETYPE?sq=b8e&sc=1&sf=101113&st=526105&documentid=56717&action=view
Aug 05, 2008 | Office Equipment & Supplies
14 people viewed this question
jasbo
jasbo
