Question about Neff W4380X1 Front Load Washer
W4380 front loading washing machine. the machine is very loud and noisy when spinning, otherwise the wash comes out okay. Please help. Thanks!
4 Suggested Answers
SOURCE: Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Posted on Oct 11, 2008
  • 228 Answers
SOURCE: neff washing machine not spinning
sounds like motor brushes have worn out will need to remove motor to replace they are inexpensive.the clicking is the relay telling motor to rotate clockwise or anticlockwise.
Posted on Oct 28, 2009
  • 16 Answers
SOURCE: I have a Neff W4380 integrated washing machine
check the drive belt sir, it is.
Posted on Mar 19, 2010
Testimonial: "I shall try all this out tonight...have ordered some carbon brushes. Hope it works. Thanks"
Machine making loud noises w6863 front loader
could be that the wights are coming loose on the drum turn the drum by hand and see if you can feel any movement in the drum if yes get them looked at also try some oil on parts
Oct 12, 2014 | Washing Machines
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Noisy when spinning
bearing gone cheaper to buy a new one
Jan 23, 2010 | Hotpoint Aquarius WF000 Front Load Washer
On the final spin the washing machine is so loud you cant even be in the same room as it, it is not vibrating externally as far as i can tell
Remove rear access panel, and remove the drive belt.
Spin drum by hand, and if it feels rough or noisy, then the main drum bearings have failed, if no noise, then check motor for noise, if no noise, check the concrete wieghts are not loose, and that the dampers are not broken or worn.
Please rate my solution.
Thanks.
Nov 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Very noisy on spin cycle only
Hi, please describe the type of noise you are hearing. If it is a grinding type noise, it is likely to be the drum bearing.
Oct 25, 2009 | LG WM1814CW Front Load Washer
Neff washing machine not spinning
May 30, 2009 | Neff W4380X1 Front Load Washer
Hello there,
Jun 02, 2008 | Neff W4380X1 Front Load Washer
Neff W4380X1 Front Load Washer Logo
23 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
