Question about Magellan Outdoors Camping, Backpacking & Hiking
I bought a screen room at academy last spring for camping. One of the poles broke during a rain shower due to water accumulating on the roof. Can I get replacemennt part?
The pole that broke is one of the main support poles so now the screen house is useless after just one camping trip.
  • 4088 Answers
SOURCE: mcculough MCP1510 chainsaw pole broke
Looks like you will have to make one to fit if no replacement is available.
Posted on Jul 08, 2009
SOURCE: I need new poles for Swiss Gear tent # SG33071F
Go to Home depot and buy a tube that fit the pole. Cut it into 5 or 6 inches for the broken areas. It costs me less than 2 dollars. Let me know how it turn out on yours.
Posted on Aug 25, 2009
SOURCE: My shower pole caddy is either too tall using the
I had the same problem. The only solution is to cut the shorter rod to the desired size. After I cut it, it fits perfectly over the bathtub. Hope this helps!
Posted on Sep 20, 2010
SOURCE: can not assemble the poles that hold the roof up.
My diagram showed holes in the roof section that would accommodate the round peg-like nub on the pillar. Without the hole it was impossible to get it to fit. Given that you will be screwing both the top and bottom rear pillars to the roof and the base anyway, I saw no need for the peg-llke nubs. I cut them off and screwed everything together as per instructions. Works perfectly.
Posted on Apr 24, 2011
jlgprop
  • 352 Answers
SOURCE: bought a tent with no poles no instructions have a model number
CONTACT MANUFACTURER FOR REPLACEMENT POLES ..OR # AND LENGTHS/DIAMETER OF POLES AND FABRICATE YOUR OWN...PERHAPS EVEN WITH SCHEDULE 40 OR BETTER PVC
Posted on Jul 30, 2012
How do you set it up
Check your manual, or look for instructions online, but the basic plan is...
1. Lay it out so the door faces where you want it.
2. Stake down the corners, yes- even if it is 'free-standing' you usually want to do this.
3. Figure out where the poles go. They usually go through cloth sleeves, or metal rings, or clips or something. They also go in arcs that may or may not cross at the top. (a manual REALLY helps with this!)
4. Slide a pole in place. if it goes through a sleeve, you usually slide it in first, then stick the ends of the poles on little metal studs at the corners. If it clips on, you usually build the pole, then run it from stud to stud, then clip the tent to the arch you made.
5. Repeat for all poles
6. Pull the rain fly in place, clip on at each pole end and as needed.
7. Pull out and stake other ties as available. This gives you more interior room, more stability and protection in weather, and improves ventilation.
May 30, 2014 | ACADEMY BROADWAY CORP Camping, Backpacking...
What is an Ensuite?
Ensuites are designed to provide you with a private room or as a toilet or shower cloak. Ensuites are available in either single or double size and come with a unit supported with poles. There are some ensuites with features like removable roof for use with a solar shower, removable floor, storage for toiletries, hook for a light and mesh windows.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
I have a Ryan's Room tent, and some of the plastic pieces that make the frame of the camping-style tent broke. How can I get a replacement part?
We had the same issue. Here's my solution.
Each tent pole is composed of 49.5 inches of half inch pvc pipe cut into three 16.5 inch pieces. This can be purchased at any hardware store. You can cut it into three pieces like the original and string an elastic line through it or just keep a piece of 49.5 inch pipe in storage to use when needed.
G Barth -- gb4cities@comcast.net
Mar 16, 2010 | Small World Home Sweet Home By Ryan's Room
Water accumulates on the front and rear driverside floor boards
do you have a moon roof. That would be the only thing with drains.
Look for water stains, trails. Could be roof ditch moldings or even sealer skips in windshield or back window. Could b a/c drain if you are running a/c
Jan 08, 2010 | Saturn L300 Cars & Trucks
97 900 s convertible - after it rains for sometime, water leaks in driver and passenger sides. Opening the roof creates a flood. Where are the drain holes and how does one clean them?
Did you solve this problem? I have exactly the same issue with my convertible 97 900 particularly in this bad weather anyone in the front seats can expect to get soaked ! I would be grateful for any advice
Nov 26, 2009 | 1997 Saab 900
Swiss Gear Tent - Broken Poles SG33071F
Take a look on amazon for replacement. here: Amazon com tent poles. I hope this was helpful. Cheers
Aug 24, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Can't figure out how to put the poles in the tent to set it up
Well, without a brand and year, it will be hard to figure out exactly. Here are some basics.
First thing, peg the tent down. (At leat the corners)
Next, locate the two longest poles. These are usually fit through a sleeve in the roof of the tent and attached in the corners via pegs or inserted into a pin. Put one corner in, then go to the other side and slide/bend the pole until it fits into the corner. Let it flop on the ground. Do the same for the other corner and the tent should be standing.
Next, if there are other poles, they could be for the front entrance or to support the rain guard. Look for peg holes or pins to place the poles into and that should give you an idea. (Also look up your model on the internet to give you an idea how it looks.)
Depending on where you are camping, you may not need the rain cover. It goes over the top and probably bungies into the peg holes.
Hopefully this will get you started. good luck. Alley
Aug 01, 2009 | Remington Sport & Outdoor - Others
Jul 25, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Leaking palomino popup trailer
improper sealing around ac if no ac the molding that runs down the center or around the perimeter of the roof do a search on rv leaks on you tube this will help you on your quest also in my personal opinon i would trade the unit cause two years or water damage you are going to have mold in the unit so just get rid of it
Jul 09, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Camping, Backpacking & Hiking Logo
35 people viewed this question
Top Magellan Outdoors Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Magellan Outdoors Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
