Question about Penn-Plax 10 Gallon Air Tech Aquarium Air Pump AT2K0 AT2KO
How to install
Ihave no idea where it goes on the tank
    Champion:
    Habit-Forming:
  • 211 Answers
It doesn't need to go on the tank at all. Put it wherever you want and run air tubing to the item(s) in the aquarium
Posted on Jun 23, 2017
Installed 99' i can get pilot light ignited, but go to turn to ON position and Pilot Light goes out? Tried for about 30-45 mins straight igniting & turning to ON...any ideas WHY ???
If you running LP check you tank if the knob isn't open all the way you wan't have enough pressure, if it is..make sure your tank is full enough to make enough pressure.. just had this prob. on a unit about a week ago, he forgot to open his tank completely.
Sep 09, 2015 | Cars & Trucks
I have 2 gas tanks do i have to have both hooked up or can i use only the rear tank
Ihave 2 tanks on my truck I keep the rear tank full in the winter and front tank full in the summer
Feb 27, 2011 | 1987 Ford F 150
Ihave a craftsman 5hp(briggs&stratton) reartine tiller that won't
Hi.....I am assuming that you have a bowl type carberator on that tiller. If so, the bolt on the bottom of the bowl, is the main jet. If you remove it, you SHOULD, see a hole drilled from the top down to a hole cross drilled thru, near the bottom. Run a small wire thru these to be sure they are clean. Other then this, I'd install a new needle and seat. You can purchase just a needle and seat set, no need for a complete rebuile kit. You will also need a bowl gasket, and if you have a primer bulb, you will also need a new intake gasket or the primer will not work worth a darn. Hope this is of some help, good luck
May 29, 2010 | Craftsman Garden
Ihave just got a lexmark e220 printer but no
Download the software from the lexmark website.
Oct 30, 2009 | Office Equipment & Supplies
When I fill the patable water tank it leaks on the inside of the trailer
If it leaks while filling it is likely any of the several fittings or it may be the 3 port check valve attached to the incomming water line. These are routinely installed backward. The idea is that when hooked to an external water supply the water goes only to the faucet and when using the tank, water can only go from the tank to the faucet. You cannot be hooked to external water and use the tank.
Any cracks in the tank should be obvious.
Use teflon plumbers tape on all screw fittings or will leak for sure. Hose clamps are also a necessity.
May 30, 2009 | Coleman Campers Grill
Hard brake pedal on cadillac
Check the vacuum line that goes to the brake booster which is on the firewall behind the master cylinder. Good luck. Let me know if this helps please.
Apr 28, 2009 | Cadillac DeVille Cars & Trucks
IHAVE A2002 HONDA lX ALL ihave done to it are oil changes.AT 85000 MILES,DO ineed tohave ittimed?thank-you sherry
If it is running fine, it does'nt need to be timed, but it would be a good idea to have the spark plugs and the fuel filter changed.
Mar 10, 2009 | 2002 Honda Civic
Penn-Plax 10 Gallon Air Tech Aquarium Air Pump AT2K0 AT2KO Logo
493 people viewed this question
Top Penn-Plax Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a Penn-Plax Fish Expert? Answer questions, earn points and help others
