Question about HP Pavilion A820n (PP165AA) PC Desktop
What does a in-line fuse look like ? - HP Pavilion A820n (PP165AA) PC Desktop
  • 70 Answers
A small glass tube with metal ends and a wire running through the middle if the wire is broken the fuse has blown.
Posted on Jul 29, 2016
Replace thermal fuse for LG microwave LMV1813ST
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won't start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don't resolve the underlying issue, the new fuse will blow too. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the line fuse.)
Sep 28, 2015 | LG Over-the-Range Microwave
I have short circuited the power cords to the cd player, the cd player and the screen is dead, the fuses in the fuse box under the steering wheel is ok. What have i broken?, can it be other fuses?
If you shorted out the power line to the radio and the power line did not have an inline fuse then the radio is probably toast. All after market radios have an inline fuse built on the power line so I'd check that first. also, some radios have a fuse that plugs into the back of them, you'll have to remove the radio to see that one.
Oct 28, 2013 | Cars & Trucks
Line fuse replacement
There is no line fuse, the only fuse is in the wall plug ,this link is for the manual
http://hoover.com/file/604/
Apr 28, 2013 | Hoover SteamVac F5914-900 SpinScrub...
What internal fuses for goodmans st101ss microwave
the modern microwaves has 2 fuses lines fuse+thermal fuse. You must see the diagram or instr. manual section troubleshooting for indication for specification of fuses. Lines fuses has 240vac and 20amps. Thermal fuses you must see the instr. manual
Jan 24, 2013 | Whirlpool GH8155XM Microwave Oven
Fuse burned out gas line?
there are no fuses near the fuel line that i know of a bad pump could burn out a fuse
Sep 05, 2012 | 2009 Buick Lucerne
RADIO HAS ELECRITIC POWER DOES NOT WORK, I CHECKED THE FUSE AND IT IS OK, WHAT ELSE COULD I CHECK?
There may be two fuses in the line for the radio; one in the car's fuse box which may be fused with other accessories, another under the dash in an in-line fuse holder. If it is not the original factory unit, it will have an in-line fuse since they are all equipped with one if installed later.
Jan 31, 2011 | 2004 Honda Accord
Got a Line 6 Spider III HD 75 at the flea market.
The unit has internal fuses. You have to take it apart. If the fuse is blown you more than likley need some service. You can call Pro Line Music 215-736-8055
Dec 11, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
How do i hook up the in line fuse and or what kind to get
In-line fuse for what exactly ? normally you just need an in-line fuse holder and break into the live wire to whatever you are wiring ( with whatever it is switched off of course ) and pop the fuse in series.
Apr 13, 2009 | Humminbird Matrix 37 GPS Receiver
Intertherm outside unit - s3ba-036k - does not run
Measure the voltage across the line. The outside unit normally runs on 220 Volts. Measuring each side of the line to ground will give 110 Volts. If your outside disconnect is of a fused type one fuse could be blown. If a fuse is blown on one side of the line you will read zero volts differential across the line.
Check the type of fuse used in the disconnect. Make sure the proper size time delay fuse is installed on both sides of the line at the disconnect.
May 17, 2008 | Heating & Cooling
HP Pavilion A820n (PP165AA) PC Desktop Logo
46 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
