Question about Goodman CLQ36AR49 Air Conditioner
Need to know how a mobile home split system is wired with just ac and 15 kW heat stripesqqq
    Genius:
  • Goodman Master
  • 1,363 Answers
You have to have 240 volts for power. 24 volts to operate cool and heat. thermostat feeds color code white to heat yellow to cool green to fan. think of the thermostat as a light switch. transformer in system feeds common to different controls & usually red to thermostat which is then switched to what it is set for.
Posted on Aug 09, 2015
3 Suggested Answers
  • 118 Answers
SOURCE: I purchaed a 15 kw heating kit for a goodman self
diagram tells it all
Posted on Oct 22, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have a split ac system with two outside units
Hi, and yes you have a short in a componant such as a blower motor has quit or shorted out, it could be a number of things. If these units are fairly new, the furnace will have a led light on it that will tell you if you have a control voltage problem, but in this case it trips the 15 amp main. This happens quite a lot. You will need to get to this heater and start looking for anything out of the unusual, burned electrical smell from the windings on the blower motor. You can unplug the blower leads at the circuit board and have someone up top reset the breaker to see if it holds. If so, its the motor that's shot. I know they are hard to work on under the house but you have no choice. You will have to do a process of elimination. It really should be easy to find as it is a dead short on a high voltage part, blower motor, circuit board. Just have a good strong light and have a 5/16 and 1/4 " nut drivers with you. Take a screw driver of each with you also, and have someone up top to work with you. It will save you a lot of time. Keep me posted, please.
Shastalaker7
Posted on Jun 11, 2010
I have a feh-015 that is in a small home with 5 registers, came from factory this way and way oversized can I run heat on first stage only?
15 kw is actually 3 stage/3 elements. Yes this would be possible depending on how handy you are. If you were to inspect your heater all 3 elements have limit switches that would turn the element off if it got too hot. Identified by a temperature rating written on the switches. Unhook one side of two of these and be sure to wrap the wire well with electrical tape. BE SURE POWER IS OFF BEFORE OPENING CABINET!!! Once complete you can always verify your amp draws each element typically draws 20 amps. Be sure your checking each line voltage. Likely have 2 breakers for a 15 kw heater, 60&30. Good luck
Feb 23, 2017 | Heating & Cooling
Split system AC has pungent brussel sprout odor
clean well all the small drainage with bleaching liquid and soap it with scented soap.also at the back of the unit that are having small drainage and through the drain hose
Apr 17, 2014 | Coleman Heating & Cooling
Retrofit newer Sanyo split AC system where old is installed
absolutly if you change refrigerants witch you prob would have to you may have to flush the linesets to cleen all the oil out but you should have no problems
Apr 08, 2010 | Sanyo Split System Air Conditioner
I want to connect 4 ton central ac to mobile home I have a license to connect ac units, but I have never done one in a mobile home. I have learned the hard way that things are done differently in homes...
does the mobile home have a modular duct system? i have converted a mobile home from a split system to a package unit and all i did was wire the package system outside 240v and 24v thermostat and we connected the existing ductwork that was in the house already to the package unit . not really sure about the code because we didnt have any requirements but it runs like a champ ..
Dec 08, 2009 | Heating & Cooling
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
Goodman CLQ36AR49 Air Conditioner Logo
57 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
