Question about Sports Collectibles Remington Rolling Block Rifles Carbines And Shotguns Collector
What year of mfg. remington 22 cal. rifle,22inch barrel,rolling block action,serial no. 108125,octagnol barrel
What is the manufacture date and approximate worth of a Remington model 6 22 caliber rifle. Model number on stock is S363171
he Model 6 Rolling block was made from 1901 to 1933.
rifles manufactured after 1921 will have a date code consisting of 2 letters stamped on the left side of the barrel near the receiver.
rifles made between 1901 and 1921, ask a question about the serial number of your rifle on the... Remington Society Forum to get a date of manufacture.
Remington serial number records are not publically available to determine a date of manufacture some old gunsmiths have the info but are not publishing it publically ie the internet.
prices seem to be low 395 high 795
Jan 27, 2018 | The Optics
I have a winchester ranger 270 cal. Rifle . Was wonde ring what model it is .... the serial number is G1871685
  • Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 ... 6.5×55mm, .264 Winchester Magnum, .270 Winchester, ... 70 Winchester rifles is the serial number ... the Winchester Model 70 rifle and Winchester Model ...
  • What is the value of Winchester ranger 270 caliber Serial? www.answers.com > ... > Firearms > Winchester Firearms Answer The Winchester 270 .22 was first introduced in 1963. It is not a collector item, or "rare". It is however a very good .22 rifle which should be enjoyed as ...
  • .270 Winchester - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/.270_Winchester Large rifle: Maximum pressure: 65,000 psi (450 MPa) Ballistic performance; Bullet weight/type Velocity Energy; ... The .270 Winchester (or 6.9x64mm) ...
  • winchester ranger .270 - Shooters Forum https://www.shootersforum.com/.../31131-winchester-ranger-270-a.html
    • 16 POSTS
    • FIRST POST: 2006-07-18
    2006-07-24 · Shooters Forum > Rifle and Rifle Cartridges > Rifles and Rifle Cartridges: winchester ranger .270 ... Winchester. Think push-feed M70 serial ... Ranger" mean? Caliber ...
  • What Is The Value Of A Winchester, Model 70, Cal. 270 ... www.gunvaluesboard.com/what-is-the-value-of-a-winchester-model-70... What is the value of a Winchester, Model 70, Cal. 270 ... of a Winchester, Model 70, Cal. 270 rifle. Serial number ... a Winchester model 70 270 cal the serial ...
  • 575 - Winchester Ranger .270 cal bolt-action rifle. Only ... www.proxibid.com > Firearms & Military Artifacts 575 - Winchester Ranger .270 cal bolt-action rifle. Only fired off one box of ammo.
  • Ranger T - Winchester LE winchesterle.com/Products/handgun-ammunition/ranger/t-series/Pages/... Ranger; T-Series; T-Series. When a ... Winchester T Series is ammunition that always performs at its best-even when things are at their worst. ... Rifle Ammunition ...
  • Winchester Ranger (M70?) .270 Win ' Gun Values Board www.gunvaluesboard.com/winchester-ranger-m70-.270-win-8295726.html I have a Winchester Ranger Serial # 5352836, 30-30 cal. Has a ... Tips for finding accurate ammunition for a .270 Win. chambered rifle. ... 1985 Winchester Ranger ...
  • Is a Winchester Ranger 270 cal a long action rifle? - Answers www.answers.com > Categories > Hobbies & Collectibles > Firearms Is a Winchester Ranger 270 cal a long ... What will excite ANSWERS.COM users for them to go ... The .270 Winchester is a great rifle for medium sized game such as ...
  • 270 Winchester Caliber Rifles for Sale - Online Gun Store ... www.ableammo.com > ... > Firearms > Rifles > Shop by Rifle Caliber We carry 270 WINCHESTER caliber rifles for sale in our online gun shop, including hunting rifles, tactical rifles, and more. We stock Browning BLR rifles, Remington ...
  • May 01, 2016 | Optics
    Need info on Remington Model 12 serial 799167
    Description: Slide-action, solid-breech, hammerless, takedown, side-ejection rifle. Introduction Year: 1909 Year Discontinued: 1936 Total Production: Approximately 832,000 Designer/Inventor: J.D. Pedersen Action Type: Slide-action Caliber/Gauge: 22 short, 22 long, 22 long rifle Serial Number Blocks: Starting: 00001
    Ending: 820,759 Grades Offered: 12A Basic Model
    12B Gallery Special
    12C Target
    12D Peerless
    12E Expert
    12F Premier
    12C N.R.A. Target Grades
    12CS, DS, ES, FS chambered for .22 Rem Special cartridges and quality of finish Variations: none
    Apr 27, 2015 | Optics
    How to determine the model and serial number of a marlin 22 rifle?
    this is copied from a site, the web address is pasted below.
    The serial number depending on the model of rifle, will be located either on the upper or lower stock tang, or side of the receiver.
    http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
    also if you find serial # you may find more info here.
    http://oldguns.net/sn_php/marlinlookup.php
    From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
    Jan 19, 2015 | Marlin Model 60 .22 Cal Rifle
    What year of mfg.108125 ?
    Do you know what model it is?
    Beings it's a .22, I'm thinking it's a Model 4, but usually those were a 22 1/2" barrel length.
    1890-1933
    Total production - approximately 356,000
    If it's a "take-down" model, it COULD be a Model 6.
    1901 - 1933
    Numbers 00001 - 498,000
    As far as serial numbers, a lot of them had the serial number on the side of the top tang, visible only with the action out of the stock.
    Not all Remington serial numbers were consectutive for the model.
    Military models were often numbered by the contract and commercial guns marked with batch numbers having little relationship to the time of manufacture.
    May 11, 2014 | Sports Collectibles Remington Rolling...
    Have a 572 remington fieldmaster serial number a1746190 trying to find yr made
    Look at the date code on the left rear portion of the barrel. The codes are posted on line.
    Feb 25, 2014 | Remington 572 BDL Deluxe 22LR Pump Rifle,...
    I have a Remington rifle which is a 22 caliber octagon barrel rolling block type serial number J282433. Any info on this rifle would be appreciated.
    Could use more info, such as markings on the barrel and or breach. The Remington rolling block type single shot goes back to the 1860'S. The first 22 calibers around 1888. The rolling block went through 8 changes. The different types or changes are where various pins and screws are located, size and shape of hammers and triggers. The New Model Number 4, made from 1890 - 1933 came standard in 22 cal. with a 22 1/2 inch Oct. barrel. It will have a small lever on the right side of the breach. Approx 50,000 of these where made between the years noted. You could very well have a model 1, 2 or a model 7, which will be rare if in very good shape as only 1000, No. 7's where made. Tracking the serial number will be hard unless you contact Remington.
    Oct 30, 2011 | Optics
    Friend jus baught an older remington with the serial number 582793. Trying to figure out what ammunition it takes because it doesnt say on the rifle
    It would help if you told us shotgun or rifle, center fire or rim fire, pump, falling block, lever, bolt action, or auto loading, etc.
    Then it would help to simply see what fits into the end of the barrel.
    Next would be to measure the length of the action.
    After 1921 Remington use letter codes for year and month, so this would have to be earlier than that, since it has no letters.
    Nov 01, 2010 | Remington Sport & Outdoor - Others
    Where is the serial number located on a remington model 37 rangemaster, cal,22 rifle?
    693f0fe.jpg Introduction Year: 1936 Year Discontinued: 1955 Total Production: Approximately: 12,200 Designer/Inventor: C.C. Loomis, A.L. Lowe, K.J. Lowe Action Type: Bolt Action – Clip Magazine Caliber/Gauge: .22 Long Rifle Serial Number Blocks: Starting: 00001
    Ending: 12300 Grades Offered: Model 37 Rangemaster
    37 Target
    37AR
    37AF
    37AX
    37AM
    37AV
    37AS Variations: None
    Dec 11, 2009 | Remington Sport & Outdoor - Others
    Sports Collectibles Remington Rolling Block Rifles Carbines And Shotguns Collector Logo
    487 people viewed this question
    Top Sports Collectibles Sport & Outdoor - Others Experts
    Bill Eager
    Are you a Sports Collectibles Sport and Outdoor - Other Expert? Answer questions, earn points and help others
