Question about NAD C545BEE
Disc error
I ve tried different disc it dont move ang further than disc error this just happened when replacing one finished lisning with freash sounds
Samsung DVD-R4000 not recognizing DVD-R discs
As a last resort you can try a firmware update if there is one but don't hold your breath. Unit may simply have lost ability to record and not be able to playback. Not uncommon - happens.
Sep 14, 2017 | Samsung DVD-R4000 DVD Recorder
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
When inserting game disc it says "disc cannot be read. Refer to the wii operations manual."
  1. Refer to the Wii operations manual.
  2. Try cleaning the disc with a lint-free cloth. Wipe the disc in strait lines, not in a circle.
  3. Don't move the Wii around while there is a disc in it. Do this to prevent further damage.
  4. Try a different disc, preferably one that is much cleaner. If it doesn't work, there is an internal error with the Wii.
Jul 12, 2011 | Nintendo Wii Console
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
We've lost 2 game discs in the xbox 360 in the last 4 months, the disk would get scratched until it freezes. First time the xbox was destroyed, second time xbox still ok but game disc has deep circular...
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on Xbox & Xbox 360 disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters, or send your discs for repair.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Feb 09, 2010 | Microsoft Xbox 360 Console
Damaged Games
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally required to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 disc repairs, visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
Hope this Helps!!
Feb 04, 2010 | Microsoft Xbox Console
Scratched discs
www.discREPAIR.ie
Hope this Helps!!
Jan 17, 2010 | Microsoft Xbox 360 Console
Dell D610 will not boot to hard disc
in os installed not corrected driver (s).
1. when goin bott press F8 and select "Dont reboot when error..."
windows go in blue screen, and write to screen what still by error (file name)
2. Try boot in safe mode. Find and delete this file.
3. Boot in normal mode.
If dont work. Boot with help WinPE bootdisk and scan your system by Viruses and Malware
Nov 07, 2009 | Dell Latitude D610 Notebook
I cant play any ps3 game
you know this happened to me too..
just call the sony company
Aug 18, 2009 | Sony Playstation 3 (PS3) Console
Solution to power caliberation error in burnings softwares
I have experienced the exact same error on my system. However, i only happened with DVD's and not CD's. So I tried a few more DVD's, got the same error. Decided to gove it one more try, and the next disc worked! Burnt very slowly but it did eventually finish. The one after that worked as well.
I suspect it's the media (Discs) you are using may have some factory defects with them. Try another disc from the same pile, or eve better, buy a different brand and try those.
Hope that helps,
Cheers
Jul 14, 2009 | Mad Dog Multimedia MD-5216CDR (20681870)...
NAD C545BEE Logo
75 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
