Question about Toshiba 15DLV77 15 in. LCD Television
Will a Toshiba 15DLV77 pick up any local channels with out a cable hook up. I had an old analog set in my kitchen that would pick up several channels with no cable hook up. Will this flat screen work that way or is there a way to make it work with no cable hook up.
3 Suggested Answers
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 13, 2009
  • 1156 Answers
SOURCE: Hi i have a Toshiba
Hi,it's not a problem from your TV, you will need to contact network provider for freeview,but before doing that, make sure you check from your next door neighbors if theirs are working fine..
If theirs are working fine, that means you might need to troubleshoot your connections and cables..
that will do..
Take care,,
Posted on Jun 16, 2011
Can anyone tell me whether I need a "Digital Converter Box" to watch local TV on my Toshiba 42hp66 or is it a "Digital Ready" unit.
All plasma TVs are able to pick up local stations without any other accessories. Hook your antenna to the 75 ohm cable input go to menu and select channel search and it will find and store any active channels you can receive...its quite easy to set up
Mar 09, 2018 | Toshiba Televison & Video
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
Just bought a vew 65 inch LED toshiba and it says digital channel signal is weak. Why
Make sure you have the menu set on digital channels not cable. Set antenna to air to pickup digital hd channels.
Nov 27, 2011 | Televison & Video
Hello! I recently moved my Toshiba 26lv610u-t from my father's place to my own. It was a short trip as we live across the street from each other. When I connected the cable to the TV, I found that all...
There are no analog channels anymore as far as I know, if you mean the channels that are local and provide an off the air signals, you need to connect an antenna for off the air signals, it may be possible that at your father's place the off the air signal was strong enough to receive them. Try going in to the menu signal type select "Air" to see if that makes a difference, of-course you will lose the cable channels until switch back to "Cable" .Hope this helps, KA
May 07, 2017 | Toshiba 26LV610U LCD TV
Not able to scan for digital OTA channels on a JVC LT-32X667 LCD
Seeing as it does not have a digital tuner in it, I would think this would be the problem, you will have to get a box for it.
Aug 23, 2009 | JVC LT32X667 32 in. LCD Television
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
Toshiba 15DLV77 15 in. LCD Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
