Question about Epson Office Equipment & Supplies
What causes error e998
When trying to print to the printer comes up with service required with a prompt E998
jackboy
  • 2985 Answers
SOURCE: Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Posted on Nov 21, 2007
aicaxz
  • 511 Answers
SOURCE: Epson Pro 7600 Service required error
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
Posted on May 30, 2009
benwabnick
  • 2404 Answers
SOURCE: service error 5100
Try this to get rid of the error:
Service error 5100 is a carriage home position error.
Turn off and unplug the printer from the power supply.
Remove any paper.
Buy a can of compressed air from an electronics shop or computer store. Use the compressed air (Not a vacuum!!!) to blast out any dust bunnies, paper particles and debris. (Don't do this with the cartridges removed as you're likely to fill the printhead with air!!)
Use isopropyl alcohol and a cotton swab (Qtip) to clean the plastic strip that runs the length of the guide rail (the metal rail that the cartridge carriage moves along), it may be contaminated with ink and debris.
Remove and reinsert the ink cartridges inside the cartridge carriage to ensure that they're connecting properly.
With the power off, carefully slide the print head (carriage) to the center of the guide rail. You should not have to force it! (There will be some light resistance but it should move quite easily by gently pushing on it with your finger.)
Close all the access doors, plug it back in, connect your USB cable and turn on the power.
As it runs through the initialization, the printer should sense that the carriage is out of position and automatically move it back to where it should be.
Good Luck.
Posted on Jul 03, 2009
aicaxz
  • 511 Answers
SOURCE: EPSON PRINTERM SERVICE REQUIRED WHEN PRINTING
Find SSC utility or adjusment program refer to your printer type. Try find at indoreset.blogspot.com. Or contact me for free resetter an instruction detail.
Posted on Oct 08, 2009
xptareq2000
  • 1447 Answers
SOURCE: My Canon Pixma MP150 printer LCD shows error
It is problem any hardware is not work properly.If you are a technician please service your printer properly.Clean all surface, blowing it.when you show E2 press black or color key
Posted on Dec 28, 2009
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
Tip
How to solve Error 0xc19a0021
<span><span><span><span><b>The error </b></span></span></span></span><span><span><span><span><b>0xc19a0021 is mostly occurred in HP printers<br /><br /></b></span></span></span></span><span><span><span><span><b>To solve the error code 0xc19a0021. There is following solution.</b></span></span><br /> <span><span><b>Follow it step by step</b></span></span><br /><br /> <ul> <li><span><span style="font-weight: bold;">Reset</span> the printer w</span><span>ithout turning off the printer, <span style="font-weight: bold;">disconnect the USB cable</span> from the rear of the printer</span></li> <li><span><span style="font-weight: bold;">Remove the cartridges</span> from the printer</span></li> <li><span>Wait for the <span style="font-weight: bold;">'</span></span><span style="font-weight: bold;">Insert Cartridges</span><span><span style="font-weight: bold;">'</span> message to display on the control panel</span></li> <li><span>Disconnect the power from the back of the printer</span></li> <li><span>Now wait <span style="font-weight: bold;">60 seconds</span></span></li> <li><span>Now <span style="font-weight: bold;">reconnect the powe</span>r If the product does not automatically turn on, press the Power button</span></li> <li><span style="font-weight: bold;"></span><span><span style="font-weight: bold;">Reinsert the cartridges</span>, and then close any open doors on the printer.</span></li> <li><span>If you receive a prompt to print a calibration page.<span style="font-weight: bold;">Print it</span> </span></li> <li><span><span style="font-weight: bold;">Reconnect the USB cable</span> to the port of the printer & then try printing again </span><br /></li></ul> By this error will automatically remove. <br /><span style="font-weight: bold;">But if u face still this error then printer service required<br /><br /></span></span></span><span style="font-weight: bold;">Keep using Fixya<br /><br /></span><span><span><span><span><span></span></span></span></span></span><span><span><span><span><span><span><span><span><span><span style="font-weight: bold;">If it helps you Please Click on "Yes" that it helped you</span></span></span></span></span></span></span></span></span></span><br />
on Jan 28, 2011 | Office Equipment & Supplies
I am having problems with printing......this is error message on the printer screen Ink system failure......0xc19a0022
Hello and Welcome to FixYa!
The error
oxc19a0022 is mostly occurred in HP printers. To solve the error code oxc19a0022,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
But if u face still this error then printer service required.
In that condition best option is to Contact HP Service Provider
I hope this solution helps you
Thank you for using FixYa
Aug 27, 2011 | HP Photosmart 3310 Printer
I have an HP c5180 and i am getting an ink system failure reading Error oxc19a0021
Hello and Welcome!
The error
oxc19a0021 is mostly occurred in HP printers
oxc19a0021,Follow the given steps
Aug 06, 2011 | HP Photosmart C5180 All-In-One InkJet...
Hi, I get a persistant error messag eon my printer message 0xc19a0035 do you know where this originated from and more important what can I do to repair the printer (HP Photosmart C5180)
The error
0xc19a0035 is mostly occurred in HP printers
0xc19a0035 Follow the given steps:-
Thank you for using FixYa!
May 08, 2011 | HP Photosmart C5180 All-In-One InkJet...
Error 0xc18a0206 for HP Photosmart 3310 All-in-One
Hello and Welcome!
The error
0xc18a0206 is mostly occurred in HP printers
0xc18a0206, Follow the given steps
Apr 19, 2011 | HP Photosmart C6180 All-In-One InkJet...
My HP B 209a All in One printer has a message that reads Ink System Failure Oxc19a0022 I have turned the printer off and on and disconnected the cords but the error message is still there. The ...
Hello and Welcome!
The error 0xc19a0022 is mostly occurred in HP printers
To solve the error code 0xc19a0022, Follow the given steps
Apr 09, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
Mp250 canon user intervention required problem
Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Office Equipment & Supplies
Printing Error
plz try by reinstalling your printer drivers and resit your cartridge
Jun 30, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
