Question about Kenmore Dryers
How do I set Kenmore 11062612101 electric dryer so the buzzer doesnt go off at end of cycle
No option on front of console, is there an off button in the rear?
gittos73
  • 244 Answers
SOURCE: Dryer will not start properly, buzzer operating
more than likely your timer is faulty too much to replace most timers about same price to replace your dryer if not cheaper
Posted on Aug 11, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric dryer won't start. #63841
Normally when a dryer starts to exhibit longer dry times, then suddenly stop working, it is an indication that the Thermal Cut-Out has blown. The TCO acts as a fuse for the heating element circuits. When an overheat condition occurs, normally the hi-limit thermostat will open to shut off the heating element. This is how the dryer regualtes its heat. However, if the hi-limit thermostat malfunctions, the TCO will blow, It is not resettable, and has to be replaced. This also means that the hi-limit thermostat could be suspect and it should also be replaced at the same time. Normally, when you go to replace one or the other they are sold as a set. This still does not rule out the possibility of a bad heating element, either.
However, you said the dryer additionally does not start. With a blown TCO or heating element the dryer will still run, but will not heat. I'll get back to this in a minute...
Now...if your dryer has been having problems drying, the first thing you need to check is the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. This could be the "electrical" smell you've experienced. If trapped lint is ending up on the heating element it will smolder and burn. I recommend the ducting be cleaned thoroughly about once per season. That's 4 times per year. If you've never cleaned the ducting, or your dryer is pushed all the way up against the wall causing the ducting to become kinked, you will have air flow problems. One way in determing air flow is to remove the vent hose from the back of the dryer and start the unit (of course, you need a working dryer in order to do this). The air should be forceful and slowly warm up to about 140 degrees. If the air flow is weak, you may have a clog inside the air baffle of the dryer (this is where the lint screen slides into). If the air flow is good, reattach the dryer hose and check at the output of the dryer vent as it exits your home. If the air flow is weak or non-existent then you know you have a clog in the vent line somewhere. Periodic cleaning will go a long way towards preventing future clogs. Dryer vent rule of thumb: The SHORTER and STRAIGHTER the vent line, the BETTER. Everywhere you have a bend or kink is an area where you will create potential collection points for lint.
Now, in determing which component is bad in your dryer. If your dryer has the lint screen on top of the unit, you will need to remove the back panel to get to the heating circuits. If your dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by pushing in on the release tabs with a putty knife. They are located along the front seam about two inches in from each side.
The heating circuit is set up and troubleshot as follows:
Heating Element (located inside the heater box) - Resistance reading should be 9-13 ohms.
Thermal Cut-Out (located on the heater box) - Resistance reading of 0 ohms.
Hi limit Thermostat (located on the heater box closest to the heating element leads) - Resistance reading of 0 ohms.
Operating Thermostat (located on the air baffle) - (May have 4 wires attached to it). Will read 0 ohms across one set of leads, 7 ohms across the other.
*Thermal Fuse (located on the air baffle) - Resistance reading of 0 ohms.
*If the Thermal Fuse blows, this will shut down the entire dryer. This is your likely suspect.
Here's a few things that will cause a dryer not to start at all:
1. Broken Drum Belt - If dryer is equipped with a broken belt relay, this will shut the dryer down.
2. Broken Door Switch - If the door switch is broken, this will shut down the entire dryer as no power is applied to the start switch with the door switch open.
3. Bad Start Switch - If the start switch does not toggle close or stay closed when released, the dryer will not start.
4. Bad Timer - If the timer does not function the dryer will not start.
5. Bad Drive Motor - No Motor, drum does not rotate, heating circuits may or may not function. DOUBLE CHECK the CONNECTOR PLUG on the Drive Motor. I have found situations where this plug came loose for whatever reason and caused the dryer to either shut off completely or work intermittently.
6. Bad A/C Receptacle and/or Connector Plug - If you aren't getting the proper voltage to the dryer, it will not run.
I just threw in those other items to give you some other things to consider. Troubleshooting is always an exact science as symptoms don't always indicate what you think the problem could be. The reason I keyed in on the heating circuitry was the intial symptoms you started with. Longer dry times are usually associated with poor air flow which usually causes something to eventually blow. I hope you find this information helpful. Please post back with any comments that I may assist you further. I hope this isn't confusing to you. Please ask for clarification if it is.
Posted on Nov 02, 2007
Jimster
  • 240 Answers
SOURCE: kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Posted on Nov 18, 2007
SOURCE: Kenmore stackable washer dryer. Dryer buzzer is
Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
Posted on Aug 26, 2009
SOURCE: Kenmore Model 96573220 won't stop at end of cycle.
I figured out it was the start switch and took the switch apart and repaired the welded together contacts. Took only a few minutes.
Posted on Dec 28, 2009
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
Feb 08, 2016 | Whirlpool Dryers
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    We have a 80 series elec. dryer, today when the end of cycle buzzer sounded, when door was closed again...buzzer continues to buzz. I can't find a part number, if the end of cycle buzzer needs replacing. ...
    Push the timer to a definate off position. Close the door. If it buzzes then more than likely you are getting power from the timer which could mean short in the timer. If you have the model # the parts places can easily find your parts.
    Dec 28, 2010 | Kenmore 800 6983 Electric Dryer
    Disengage buzzer on Kenmore 400 dryer
    The buzzer is inside the control switch area. Its about the size of 4 stacked 50 cent coins. Kill the power to the drier and then open the control panel and locate the buzzer. Remove the two wires; using electrical tape, you can tape up each wire end and then secure it out of the way. :?) DRRXR
    Jan 17, 2009 | Kenmore 73952 Gas Dryer
    Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
    • the buzzer is located under the control panel.
    • you can unplug it.
    • unplug the dryer or turn the breaker off first
    • then take out the 2 screws on both sides of the control panel
    • bull it forward toward you and unhook it from the case
    • you should see the buzzer with two wires going to it
    • only need to disconnect one.
    •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
    Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
    Mar 16, 2007 | Candy CIV60 Electric Dryer
    Dryers Logo
    13 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
