Question about Kenmore 74112 Gas Dryer
How do I turn the buzzer off my Kenmore dryer
There is no button on front, can I disengage from the back panel?
Jimster
  • 240 Answers
SOURCE: kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Posted on Nov 18, 2007
  • 833 Answers
SOURCE: turn off buzzer
Assuming you mean the end of cycle alert. The only way to do this is to follow the wiring diagram and install a switch to cut it off.
Posted on Dec 21, 2007
SOURCE: Dryer not heating
what is the model #the heater is not in the back of the he4.
Posted on Nov 05, 2008
  • 29 Answers
SOURCE: disengage buzzer on Kenmore 400 dryer
The buzzer is inside the control switch area. Its about the size of 4 stacked 50 cent coins. Kill the power to the drier and then open the control panel and locate the buzzer. Remove the two wires; using electrical tape, you can tape up each wire end and then secure it out of the way. :?) DRRXR
Posted on Feb 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: annoying buzzer alarm
Unplug Dryer Remove back cover on control panel and disconect wires to buzzer. Sea Breeze
Posted on Mar 28, 2009
FEQ1442ES1 works but no heat
Instructions
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
Jan 09, 2013 | Dryers
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    On the Kenmore 70 series, can the buzzer be disconnected? Our 5 month old gets startled each time that damn dryer buzzes (It seems like it last forever!)
    Hi, did you try turning the buzzer off with the knob on the right side of the operation panel (which is also used as the start button)? If you turn that knob to the left, it should turn off the buzzer.
    If it still buzzes, the switch behind that knob may be faulty. You can get at it by removing the panel at the rear of the dryer (6 screws) and then you can test it and adjust its internal contacts if need be.
    Hope that helps!
    Mar 03, 2010 | Kenmore 98702 Stacked Washer/Dryer
    Buzzer at end of dryer cycle too loud. Can I turn it down or disengage it?
    Usually, there is a front panel control for buzzer volume or turn it off completely. If nothing there, you will need to locate the buzzer and either remove and tape the wires or if the unit has an opening, stuff some paper into the opening.
    Sep 26, 2009 | Dryers
    Annoying buzzer alarm
    Mar 28, 2009 | Kenmore 400 6942 Dryer
    Dryer buzzer is SO LOUD - How can I adjust volume/turn off?
    Buzzer mounted to back of control panel.
    **UNPLUG POWER BEFORE REMOVING CONTROL PANEL OR TOUCHING -ANYTHING-!**
    Located on left side of control panel, bolted to back. Small rectangular device with two connections and no associated button or dial.
    Remove the panel and disconnect one of the leads. Fold the connector back against its wire, carefully and securely tape the connector with electrical tape so it cannot touch anything. Also tape the connector on the buzzer that you removed the wire from.
    Re-assemble the control panel.
    As with anything mechanical, hours of frustration trying to take something apart can be avoided by taking a few minutes at the beginning to look closely at how it is assembled.
    Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
    Disengage buzzer on Kenmore 400 dryer
    Jan 17, 2009 | Kenmore 73952 Gas Dryer
    Turning the beep off?
    1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down. Step2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device. Step3Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels. Step4Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Jan 11, 2009 | GE Profile DPXH46EA Electric Dryer
    Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
    • the buzzer is located under the control panel.
    • you can unplug it.
    • unplug the dryer or turn the breaker off first
    • then take out the 2 screws on both sides of the control panel
    • bull it forward toward you and unhook it from the case
    • you should see the buzzer with two wires going to it
    • only need to disconnect one.
    •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
    Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
    Turn off buzzer
    some models have a buzzer in control panel which can be unpluged wire sealed off ather built into time and can not be turned offf good luck
    Mar 04, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
    Kenmore 74112 Gas Dryer Logo
    43 people viewed this question
    Top Kenmore Dryers Experts
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
