Question about Garden
How to fix a leaking pressure washer
How to fix a leaking greenworks pressure washer
Replace gasskets and washers
Posted on May 14, 2014
I have an electric greenworks 1700 psi pressure washer that starts then stops repeatedly how do ya fix it
Sounds like the thermal switch is shutting it down. It is either bad or something is causing the motor to run too hot.
Jul 30, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
On page 25 under trouble shooting for greenworks 1700 it states that you can turn nozzle tip to a high or low pressure position. how is that done?
The owners manual was badly written by someone in China whose English is a second language. The output pressure is set at the factory. The only thing the consumer can do is change the spray pattern by changing the nozzle. 0 for pinpoint, 25 for small fan spray pattern, 40 for large fan spray pattern, and Soap for dispersal.
Jul 08, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
Hi, water intake leaking on greenworks 1600 ele. sprayer thanks! its brand new!
Send it back - if you are in the UK the SOG act applies if in the US then Tough
Oct 23, 2015 | Greenworks 1600 PSI 1.3 GPM Electric...
Brand new, water leaks at intake, intake seems loose?
Hi Dave:
Not that I probably could not repair it, but since it is brand new, I'd take it back to the store where I bought it, if for no other reason than to avoid possibly voiding the warranty.
I have a model 51012 washer..I need replacement nozzles. where can I get them? thanks.
Go to their website and check out support. Some outfits will only sell parts thru their "authorized" dealers.
Jul 19, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
Pressure wand is leaking at the out let end, and pump has a small surge when setting at a idle
Sounds like water is leaking past the shutoff valve on the wand. Check your owners manual parts diagram to see if there is a washer or o-ring to replace.
Apr 16, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
The pressure washer leaks from inside casing letting out water/soap might be affecting pressure of hose?
If your part of the country reaches freezing temperatures during winter, the pump probably froze. This can cause cracks to brass and (especially) aluminum pump heads. It is worth opening up the case; sometimes I find loose fittings (caused by freezing) which can be tightened up and everything is fine. If it is not freeze damage, the check valve may have gone out on the soap injector, causing pressure to back flow through the inlet barb. Otherwise, you may have a worn/leaking pump seal.
This is a consumer (throw-away) pressure washer. If it's not a loose fitting which can be tightened, the unit is probably not worth fixing.
Jul 01, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
How do you take the hose reel off on a greenworks 1700 psi pressure washer?
There should be a clip that holds it in place, see link.
http://www.ppe-pressure-washer-parts.com/greenworks-51012-pressure-washer-parts
Jan 12, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
