Question about Konica Minolta bizhub C351 All-In-One Laser Printer
What does the p14 error message mean on a develop 550
  • Konica Minolta Master
  • 6,161 Answers
DO you mean C550 Copier/Printer? P-14 means
problems with the following
1. PH relay board (REYB/PH)
2. Printer control board (PRCB)
3. PH unit
4. Imaging unit
Recommend you get a tech out to look at this problems
Print head (PH) contains the LASER. Printer Control Board $$$$$$$$$$$$$$$. PH/ REYB?PH board ALSO $$$$$$$$$. Again have tech come out look at this machine.
Posted on Dec 29, 2015
550 5.5.1 Protocol Error
550 generally means the mailbox is unavailable. Make sure you typed the address in correctly. If you're just hitting reply, the person who sent the original message may have misconfigured their email client with the wrong "reply to" address.
Mar 30, 2016 | IncrediMail
What does protocol error 550 5.5.1 mean
Error 550 5.5.1 means the user or your friend whom you want to send mail or message that user does not exist.
To get rid of this error first check the email address. If email address is ok then go to setting and check for reply to: section. if there is any email you have specified then delete them and now try to send email.
Mar 06, 2016 | Computers & Internet
C 2454 Code
Printer control board (PRCB) 4 choice $$$$$$$$$$$$$$$$$$$$$$$$
Developing motor/K (M23) 3 choice
TCR sensor/K (TCRS/K) 2 choice
1. Clear black developer counter, replace the black developer an run required procedures
Apr 02, 2014 | Konica Minolta Bizhub C6501 C6500 Ikon 550...
How do i clear message c2558 for the konica minolta bizhub 215
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Feb 24, 2014 | Office Equipment & Supplies
Ihave been sending messages and they have been failing. postmaster has been failing, and sending me messages back saying this automatially generated diogsitic problem,diagonostic code is smtp;550
550 error code means the mailbox of the recipient your sending it to either is unavailable(server it is on is down) or the mailbox doesn't exist.
Sep 18, 2011 | Computers & Internet
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
Jan 27, 2011 | Lexmark C540N PROD SPECS TBD Printer
How do i get the top of the mixer off to fix the gears? i'm unable to find a way to remove the lid.
You mean the transmission cover: here what I did to removed it: all item number reference to part catalog
1- remove top cover (# 1, p10)
2- removed 4 crews #55,56 p10
3- remove cap bearing retainer (#9, p10))
4- remove #1,2,3,4 p14
5- remove retainer twin bearing (#8, p10)
6-remove #32,33,34 and 45,46,47 p14
7- remove 4 crews (#32 p10) and pull out shift handle assembly
8- use a wooden rod (1/2 ") and push though the shift handle access and up to the transmission cover to push out the cover, be carefull not to damage gear tooth.
Good luck and have fun
Apr 18, 2010 | Hobart A200 Stand Mixer
Sharp mx-2300N printer error maintenance required code vk
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Dec 23, 2009 | Sharp MX-2300N Color Copier
WHAT DOES THE ERROR MESSAGE 377 MEAN?
It means that there is Magenta toner density sensor error.Try to reset or replace Magenta development unit and then turn the printer off and back on.It should fix the problem,providing that the Magenta toner supply channel is not clogged up and functioning properly.
Oct 08, 2009 | Ricoh Aficio AP3800C Laser Printer
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
