Question about Asrock 845GV (P4I45GV) Motherboard
WHICH IS THE RTC ic ?
SYSTEM HANGED AT BOOTING
If i enable the USB drive in CMOS.after booting the system is hanged.only mother board name mercury is shown.
The problem is with the Installed USB Devices. Check whether you are using any of the USB slots in your system. If any printers or any other USB devices are installed the boot will check with these devices, so your system is getting hanged. Try to disable the USB booting or else remove the usb device and then boot. This will resolve your problem.
Oct 19, 2009 | Mercury P4VM800M7 Motherboard
My mp4 player is getting hanged while booting up process
my creative mp4 is hanged . what can I do for fixing it ?
would you please help me ?
Sep 23, 2009 | SanDisk Sansa e270 MP3 Player
No booting / No Display But fan is running
CHECK YOUR SYSTEM RAM IF IT IS OK THEN THERE IS A PROBLEM WITH THE MOTHERBOARD
Jul 08, 2009 | Acer Aspire 4730-4947 Notebook
Getting hanged
try to boot into safe mode by pressing F8 while restarting..then in safe mode goto>start>Run>type msconfig>and in start up tab disable the un necessary programs...then restart
Apr 11, 2009 | Acer Aspire 4720 Notebook
About my Compaq Evo N800v Notebook PC laptop screen problem
My laptop is not working in the proper manner.Because for the screen the belt is may be some loose contact.some times the screen is shaking at the time of booting and immediately hanged.Then system is not working.Some times if we press upon the screen then it will work in good manner.If we remove the pressing hand,immediately the screen shakes and hanged the contents immediately.
Apr 06, 2009 | Compaq Evo N800v Notebook
Hp nx 6110 a power-on-password
Hi, try this:
- unplug from mains
- remove laptop battery
- remove real-time clock (CMOS) battery.
- wait 5 minutes
- replace the RTC battery and then
plug in - without the laptop battery.
The laptop battery cannot be present
when you remove the RTC battery
and shouldn't be there when you power on.
Try
Mar 31, 2009 | HP Compaq nx6110 Notebook
Dell d600 video problem
Forget the non-sense.
  1. Remove the battery
  2. Open the RTC Battery compartment
  3. unplug the RTC battery
  4. Press the power button to dissipate stray voltage
  5. Re-install RTC battery and cover
  6. re-install main battery
  7. Re-boot and enter set-up to change date time etc.
Apr 17, 2008 | Dell Latitude D600 Notebook
Hard drive password locked
Have you tried removing the battery, open the reserve battery door, disconnecting cmos (RTC) battery, pressing power button, installing RTC battery, install battery, power up?
Apr 10, 2008 | Dell Latitude D505 Notebook
System Booting Problem
ITS EITHER A HARD DRIVE OR A MEMORY ISSUE
Oct 15, 2007 | Computers & Internet
Asrock 845GV (P4I45GV) Motherboard Logo
14 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
