Question about iPhone Apps
Zauuuyt end with e - iPhone Apps
Answering and ending calls
Answering and Ending Calls - Samsung Galaxy S 5 User ...
eguides.sprint.com/support/...s.../answering_and_ending_calls.html
Open topic with navigation. Answering and Ending Calls. Manage settings foranswering and ending calls. From home, tap all apps icon Apps > settings icon ...
Answering Ending Calls - Samsung Galaxy Mega User Guide
eguides.sprint.com/support/eguides/.../answering_ending_calls.html
Open topic with navigation. Answering/Ending Calls. Manage settings for answering and ending calls. Press Home key and touch Menu key > Settings > My ...
Answering and ending calls - Bose
Dec 29, 2015 | Cell Phones
I would like to remove my items that i have listed on e-bay
Log into your E-Bay account and cancel your listings.
Oct 08, 2014 | Computers & Internet
Serial#854480 model94 Winchester rifle what year was it made
serial SI100808419 Samick guitar does it exist
Mar 11, 2012 | Computers & Internet
How to replace town and country side mirror turn signal
With your thumb push the narrow end of the light back. The idea is to slide the light back a little toward the fatter end. This should free up the retention clip at the narrow end. Then gently pry out the narrow end of the light. I used a thin screwdriver and a piece of old leather to keep from scratching the mirror body. Once the narrow end is out the whole light will come out. unplug the old light. Do the reverse to install. Plug in the light. Put light in fat end first. Pivot the narrow end in. Slide the fat end towards the narrow end to seat the retention clip.
Jan 13, 2012 | Chrysler Cars & Trucks
I bought a new plastic end piece for the hose but can't get the old one off the hose to change it???
Soak the end of the hose it very hot water to soften the end of the hose. Then insert a screwdiver inside the plastic end piece and flex the end of the hose inward and pull the old end off. To install the new end, bend the end of the hose into a "kidney bean" shape and push the new end on.
Jan 02, 2011 | Kirby G6 Bagged Upright Vacuum
How to create an object of VSI-Fax like in winfax
For VB
Private Sub Form_Load()
Dim sendObject As Object
Dim ret As Integer
Set sendObject = CreateObject("Winfax.SDKSend")
ret = sendObject.SetSubject("TEST!!!")
If (ret = 1) Then
MsgBox ("SetSubject Failed")
End
End If
ret = sendObject.SetKeywords("Test")
If (ret = 1) Then
MsgBox ("SetKeywords Failed")
End
End If
ret = sendObject.SetResolution(0)
If (ret = 1) Then
MsgBox ("SetResolution Failed")
End
End If
ret = sendObject.SetQuickCover(1)
If (ret = 1) Then
MsgBox ("SetQuickCover Failed")
End
End If
ret = sendObject.SetCoverText("This is a Test.")
If (ret = 1) Then
MsgBox ("SetCOverText Failed")
End
End If
ret = sendObject.SetUseCover(1)
If (ret = 1) Then
MsgBox ("SetUseCover Failed")
End
End If
ret = sendObject.ShowCallProgress(1)
If (ret = 1) Then
MsgBox ("ShowCallProgress Failed")
End
End If
ret = sendObject.SetTo("Somebody")
If (ret = 1) Then
MsgBox ("SetTo Failed")
End
End If
ret = sendObject.SetNumber("#######") 'My fax number
If (ret = 1) Then
MsgBox ("SetNumber Failed")
End
End If
ret = sendObject.SetAreaCode("###") 'My area code
If (ret = 1) Then
MsgBox ("SetAreaCode Failed")
End
End If
ret = sendObject.SetPriority(1)
If (ret = 1) Then
MsgBox ("SetPriority Failed")
End
End If
ret = sendObject.AddRecipient()
If (ret = 1) Then
MsgBox ("AddRecipient Failed")
End
End If
ret = sendObject.LeaveRunning()
If (ret = 1) Then
MsgBox ("LeaveRunning Failed")
End
End If
ret = sendObject.GetRecipientCount() 'this shows 1
MsgBox ("Recipient Count: " & ret) 'recipient
ret = sendObject.Send(1)
If (ret = 1) Then
MsgBox ("Send Failed")
End
End If
End Sub
If u like that Appreciate me by giving vote.
And try to be little specific while u ask question, that means, if u want code on any object ask for which language u r in need of?
Oct 19, 2009 | Esker VSI-FAX 4.x (25301) for Unix
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
I need coding with description
The various combinations of these attributes may result in code that looks something like this: sub calcPay(emp) // Calculate pay subroutine if emp.isManager // field reference if emp.isExempt if emp.isPartTime foo_1 else foo_2 end if else // non-exempt if emp.isPartTime foo_3 else foo_4 end if end if else // non-mgr if emp.isExempt if emp.isPartTime foo_5 else foo_6 end if else // non-exempt if emp.isPartTime foo_7 else foo_8 end if end if end if end sub Here we have 8 different "cells" based on all possible combinations of the 3 attributes. (Note that some cells may be error messages for invalid combinations.) Variations of this structure are not uncommon. Thus the question: how does one "fix" it? One approach is to convert every IF block into a separate subroutine. sub calcPay() if emp.isManager doManager() else // non-mgr doNonManager() end if end sub //----------------- sub doManager() if emp.isExempt doMgrExempt() else // non-exempt doMgrNonExempt() end if end sub //----------------- sub doMgrExempt() if emp.isPartTime foo_1 else foo_2 end if end sub //----------------- sub doMgrNonExempt() if emp.isPartTime foo_3 else foo_4 end if end sub // etc.....
Apr 10, 2009 | Computers & Internet
I can't get into phone
##33284+send=Debug Mode
##3328873+send=feature menu
##7764726+send=program mode
##2773+end=diagnostics screen
##7738+end=change p_Rev
##2240+end=more S/W test
##4771+end=free gps
#5625*+end=reveals unlock code
##667899+end=mms test mode
#4357*+end=help
#46484258# factory test mode
*#6870 + END=MTP MODE Off
*#6871 + END=MTP MODE On
*#7678 + END=MTP Menu
here this might help I tested all these codes myself on verizon blitz every one works
Apr 01, 2009 | UTStarcom Blitz Cell Phone
What is the problem of that action script
the encryption was made using this product :
http://www.amayeta.com/software/swfencrypt/#00
and its not possible to unobfuscate it.. unless you are an expert/genius and you have a very very huge free time to do it. :)
Feb 22, 2008 | Macromedia Flash MX
iPhone Apps Logo
26 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
