Question about Dishwashers
Lg ld 1415t1
Error signal comes up in display and bell starts chiming today cycle stopped
  • 641 Answers
SOURCE: "PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Posted on Sep 13, 2007
  • 3230 Answers
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
KevinWhite
  • 1902 Answers
SOURCE: Hi, I have a LG
Hello & Welcome to FixYa
If the drain pump is clear then the problem is with the timer/control board that is bad and needs replacement, before replacing you can open the control and then remove the cables connecting the control and then insert it back to check if it reset, if it won't then it's better to replace the timer/control board. Please get back to me if you have any other questions.
Kevin
Posted on Jul 10, 2011
caroldon
  • 17130 Answers
SOURCE: closing mechanism on the door
It can be the lock mechanism. Please check on the link below;
http://www.espares.co.uk/advice/dishwashers/a/3/1288/how-to-fix-a-broken-dishwasher-door-lock-hotp.html
Posted on Jul 19, 2011
caroldon
  • 17130 Answers
SOURCE: hi i have an LG
It is so common that the drain leaks in many ways and is the most problematic fault in a dish washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
please check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3/1292/how-to-replace-a-leaky-dishwasher-door-seal-h.html
Posted on Jul 29, 2011
My LG 1415T1 sound horrible when running
Normally when one hears a continuous noise throughout the cycle, it is caused by the pump motor bearing having become wet due to a leaking seal. The roller bearing closest to the seal becomes rusted and then creates this awful noise. The pump impeller is a sealed unit so you will have to replace the pump.
Apr 03, 2014 | LG Dishwashers
What does OE code mean on LG LD-1415T1 Dishwasher
a draining problem either the drain hose is kinked or blocked or the pump impeller is jammed with something so its not turning or a bad pump good luck
Dec 15, 2013 | LG Dishwashers
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Error Code OE
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
1 F in dispaly window
well,i have the same problem.the solenoid doesn't open for the water to flow in.... but still working on the problem....
Feb 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Bell rings
You have either a water fill or water temperature problem.  Not sure because you couldn't be specific on the error problem.  You will need to call a qualified LG technician to diagnose this properly.
Apr 10, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
Top Dishwashers Experts
