Question about Lenovo H430-2558-1CU Desktop PC
Adding a brother printer to a hp2000 with 3 usb ports
Which usb port, I have 3 on my hp2000 laptop is to be used as a lpt1 port?
    Problem Solver:
  • 30 Answers
USB ports create a virtual prot for USB-based printers, example; USB001, USB002, etc. It will not be LPT1.
Posted on May 23, 2014
3 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: usb devices
Do you mean that the USB device unloads and reloads when you hit a key?
Does it do it with a different USB device?
Remove all USB devices, then:
Go to Control Panel > System >Device Manager >Hardware >
Un-install the USB ports, then restart the computer.
Let me know the result.
Please remember to rate all users who assist you for free :)
Posted on Oct 04, 2008
maxcarson
  • 7627 Answers
SOURCE: where is LPT1 USB port on Lenovo H430 for printer
Few computers use LPT1 connections, most use USB .Use a Printer cable with a USB to laptop. Your printer should have a cable that has a printer connection to a USB laptop connection? What is the Printer?
Posted on Dec 13, 2012
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Where is LPT1 USB port on Lenovo H430 for printer
Dec 13, 2012 | Lenovo H430-2558-1CU Desktop PC
I bought an HP Deskjet F4400 printer for college and it keeps saying the printer is offline. I have a Macbook Pro, so there's no "Control Panel." I looked under "system preferences" but was unable to right...
its likely the printer port that the printer is assiged to. I assume its plugged in via usb. power on the printer, then connect the usb cable. go into the printer properties, look for printer port. do not use LPT1 LPT2 or Com anything. make sure printer port is set to the USB port. Its a mac so it may be tricky to find. Quite often these printers set to LPT1 by default which is incorrect on a USB printer. good luck.
Aug 25, 2010 | Office Equipment & Supplies
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
New comuter with windows vista and can not load printer hp photosmart 7660
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click the Windows icon, click Control Panel , click Hardware & Sounds , and then click Printers .
3. Click Add a printer .
4.Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select "Deskjet 5600"
9. In the Printer name text box, type the printer name, and then click Next . The printer driver starts to install.
10. After the computer displays a message that the printer was successfully added, connect the USB cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Now let's configure the driver
1. In the printer folder, right-click the name of the printer, and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to USB.
Now let's make a test
1.Click the General tab.
2. Click Print Test Page
Your printer should start printing in a few seconds.
Dec 02, 2008 | HP Office Equipment & Supplies
HP4500 Color laser and setup using USB
just try to change the LPT1 port to usb port..
Oct 28, 2008 | HP Color LaserJet 4500n Printer
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
Lenovo H430-2558-1CU Desktop PC Logo
32 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
