Question about UltraLast Multiposition Universal Chargers (ULCC4H (NABC)) Battery
User instruction sheet for ultralast ulcc4h
When charging is the led light one color and change color when fully charged
Charging light shows green--manual says charged when light goes off-_I would expect a red light when charging--Is it charged when green light shows???LUMIX ZS8
Hi if u r using DE-A60 or DE-A60A CHARGER / when charging green LED is on when fully charged LED Turns off ...cheers
Nov 01, 2017 | Health & Beauty
On the Alcatel a206g, how can I tell when the battery is fully charged? Does the light change color?
When the battery is fully charged the image of a battery
will display on the screen with 4 bars.
link to on line pdf manual
Alcatel A206G User Manual
Jun 02, 2016 | Alcatel Cell Phones
How long does it take to fully charge a Sophix #TAB730G & how do I know when it is fully carged?
If you don't have a user manual, I can only guess, Usually there are led's that will come on when charging and go off when charged, sometimes the LED's will change colors, red to green ,for instance. The time depends on the level of charge required, 10%,25%, 50%, 75%...etc.
Dec 25, 2012 | Computers & Internet
I need to READ the battery charger instructions for a Minolta Dimage G500?
I suggest you charge the battery overnight and in the morning if the LED does not change color then the Red LED on the charger only indicates that there is mains power to the charge adapter.
Jul 11, 2012 | Konica Minolta DiMAGE G500 Digital Camera
How do you tell when the battery is fully charged. It continues to show that it is still charging when it would have to be fully charged. The battery is a 3.8V which isn't mentioned on the charger...
The light usually changes colors or goes from flashing to solid even from a light being on it going off when charged. Every camera is different. Normally a good hour will fully charge most camera batteries.
May 13, 2011 | Cameras
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
I am trying to figure out what the buttons on the underneath of my laptop are for, they show a battery sign and mine only stays charged for an hour?
That battery LED shows up when you are connected to AC power. When the battery is charging, the light is up. However, when it is fully charged, it will change color or disappear or does not light. But I am begging you to not use your laptop always with the AC power so as not to destroy your battery. When you are at home, plug your laptop to charge but dont open it. When it is fully charged, remove the battery and turn it on while the battery is out. It is the safest way to conserve and lengthen the life of your battery. Use only your battery when you are in places where there is no power outlet or when you are on the go.
Regards!
Sep 25, 2009 | Toshiba Satellite A135-S2276 Notebook
We bought the GMRS1072CH walkie talkies last year but never used them. We're trying to charge them now but we're not sure if they are taking the charge. The red lights come on but is there supposed to be...
Depends, is there another LED present that yuo would expect to light up? Not familiar with these chargers. Ours do a number of things to let you know what is going on. A dead battery lights up the charger with ared LED, it blicks red if the battery is defective, and goes green when fully charged. along the way I think there is an amber LED indicator but I am not sure what that does.
Your may go green or just blank out when fully charged.
Jun 30, 2009 | Radio Communications
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
What color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
Nov 27, 2008 | Duracell NiMH AA/AAA Battery Charger with...
UltraLast Multiposition Universal Chargers (ULCC4H (NABC)) Battery Logo
120 people viewed this question
Top UltraLast Cameras Experts
Are you an UltraLast Camera Expert? Answer questions, earn points and help others
