Question about A & A Manufacturing Electronics - Others
Jasic arc 200 alarm oc notweding - A & A Manufacturing Electronics - Others
Eoc alam
E.OC is an over current error.
The inverter is sensing a short on the U/V/W terminals. This could be a shorted motor, motor leads and an internal short in the inverter.
Disconnect the motor leads from the inverter, and run the inverter as you normally would.
If the E.OC error does not occur the short is external of the inverter.
If the E.OC occurs, then the short is internal to the inverter.
Nov 26, 2013 | Inverter KEB COMBIVERT F5
I have a electrical problem in my 200 AMP murray braker box.It was put in around 1975.It looks like the 200 AMP main breaker is arcing.When the fridge starts the lights go dim..Will another braker work?
The best answer I can give is a new breaker might solve the problem.If the arcing has not damaged the bus bars where the main breaker is connected. Be sure to check to see that all connections are tightened properly. If you are using aluminum wire be sure to use a deoxidizing compound. Tighten the aluminum connections, wait a while, and recheck tightness.
Hope this helps.
. Bob
Nov 06, 2013 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
OC failure after changing power supply
oc failure computer.
oc failure boot.
oc failure error.
oc failure bios.
oc pc failure.
oc power failure.
your description don't have so many details.
GOOGLE IT.
Jun 11, 2013 | Gigabyte Computers & Internet
Jasic 250F Mig, OC light on, now no power, only fan going.
Check the internal fuse. If that is okay, check all connections and check for continuity across the heavy windings. Transformer may have burned open at a power tap. Or the heavy contactor burned out.
If you do not have a manual, They do not have any douwnloadable at their website http://www.fsh-welding.com If you do need to contact them, I hope your French is up to snuff-
http://www.fsh-welding.com/contact.htm
Jan 24, 2012 | Welding Tools
Cannot locate the driver for an ethernet controller on my gateway 200 ARC...I don't know which ethernet controller i have?
Your drivers are here http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=10447&os=&type=
Download PC Wizard to detect what type of controller you have, if it does not say in device manager ( right click my computer / manage / device manager)
Aug 20, 2010 | Gateway 200 ARC Notebook
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
Arc fault circ breakers are very warm
if its a 100 amp panel only 5- 20 amp breakers, if its a 200 amp panel 10- 20amp breakers
Dec 23, 2008 | Eaton ARC FAULT CIRC BREAKER
Arc fault circ breakers feel warm
If the breakers are 20 amp and the panel is rated at 100 amps, only 5 breakers. if the panel is 200 amp, only 10, 20 amp breakers and so on
Frigidaire frf170ff alarm keeps going off, but has been no powercut and door has not been open but temperature will not go down to -18 oc it is at -9 oc and superfreezer does not alter temperature!
We have same problem. Its stored in a intergal garage had it since Jan 08, no problem until now. The last 3-4 days its been beeping the alarm, temperature according to the display varies between -9c and 11c/ Despite doing the fast freeze over night temperature hardly improved at all around -1c. to 12c. Its quiet a cold night tonight 14c in garage yet temperature of freezer remains at -11c
May 05, 2008 | Refrigerators
Alarm trouble
OC means a wiring problem between the keypad and the alarm. Take the keypad and hook it up in the alarm cabinet and see if it works there.
Jan 22, 2008 | Cisco Alarm Expansion Panel (15454-AEP)...
Electronics - Others Logo
Top A & A Manufacturing Electronics - Others Experts
Are you an A & A Manufacturing Electronics - Other Expert? Answer questions, earn points and help others
