Question about LG DLG5988 Gas Dryer
Everytime i turn on my lg tromm it says check filter
I have cleaned the filter every time i use the dryer. i have to dry everything at least twice. i use a long brush to clean down in the filter as well.
    Problem Solver:
  • 11 Answers
TRY TAKING OFF THE VENT HOSE AND RUN A CYCLE WITHOUT IT AND SEE IF IT DRYS FASTER....YOU MAY HAVE A CLOG OF SOME SORT IN YOUR WALL
Posted on Jun 23, 2009
Fisher Paykel DE06 electric dryer. I have to run loads twice to dry.
Did you check the duct going out of house for obstructions?
Oct 14, 2017 | Fisher Dryers
Why isn't my model DE512 drying properly?
I find that if your filter are not cleaned out they will not dry , must be cleand out , unless it has a gas valve problem
Mar 07, 2015 | Maytag Dryers
Electric dryer taking longer to dry clothes
Must be past the filter-problems in the duct work and hoses. get one of the refrigerator cleaning brushes from the hardware store and a duct cleaning kit, or a rope and rag. clean out the dryer ducting, & hoses as good as you can and check the outside exhaust port. Sometimes these have trap doors that become stuck from old age, even though ductwork is relatively clean. problems can also exist after the filter but before the dryers exhaust port in the back try to clean that out as well.
Nov 09, 2013 | Dryers
Heating up but not drying clothes
Your vent could be clogged with lint and debris. First remove the lint filter and clean the visible lint. Then run it under warm water and use a soft brush to gently scrub to remove any chemicals from softeners that may be on the filter. While the filter is drying completely, use a dryer brush (available at most stores that carry appliance accessories) and clean out the vent as far as the brush will reach. Next go to where the vent exits your building, lift the flap and clean that area as well.
What happens is that lint builds up over time. The heat and moisture causes it to matt up and it can't be blown out by the mild wind force created by the dryer. The only way to get the matted material out is to clean with a brush and remove it.
I hope this helps you. If it does, please come back to Fixya and rate my advice.
Jul 27, 2011 | Bosch Dryers
My whirlpool gas dryer is taking twice as long to dry clothes. I cleaned all vents and filter and also ran it with the exhaust vent disconnected and dryer still did not dry any faster, but there was a...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 25, 2010 | Whirlpool Dryers
My legacey washer is leaving lint on clothes
Of course you've probably already done this but if not, check the filter and clean it. Additionally, you might need to wash it to remove residue from dryer sheets and BE SURE TO DRY IT BEFORE PUTTING IT BACK IN THE DRYER. If the filter is clean and washed and you're still having lint, get a dryer brush and clean down in the area where the filter goes. Also go to the vent area outdoors and clean that with the dryer brush. That area can become clogged over time and prevent the dryer from effectively removing the lint. Furthermore, check the exhaust piping. If it is bent, gently move it a little to dislodge any lint that might have gotten stuck there over the years.
Nov 04, 2010 | Maytag Washing Machines
Dryer not drying without running twice. It's not clogged with lint and the filter has been cleaned. It's actually blowing outside like normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 11, 2010 | Dryers
I washed, then dried a rug that instructs to "air dry." (Now I see the instructions for proper care...) I have A LOT of little rubbery pieces in the dryer and I have a fear of setting the dryer on fire...
even tho you've cleaned out the lint trap and the drum, small pieces of your rug have most likely passed by the filter, or thru the seam where the drum meets the front and rear panels. I would recommend pulling off the front cover, and vacuuming out the "innards" of your dryer. That way you can be confident that you're good to go. You can also remove the lint filter and with a vacuum edging tool **** out any visible "chunks" in the duct. Let me know if you need assistance opening up your dryer.
Aug 28, 2010 | Whirlpool LER4634J Electric Dryer
Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Whirlpool dryer wed5700sw
you need a dryer vent brush first,bought at home depot cheap,and clean the entire vent to the house,then clean where the vent hooks up to the machine,if your filter is where your door is pull out the filter and stick the brush in there and pull out lint,also use your vacume,remember you let some lint out when you let the hose blow out but theres a lot more there to clean,and also unplug your machine as you do this,if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
LG DLG5988 Gas Dryer Logo
789 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
