Question about Cameras
Where can i find a manual for logic logd1218 radio
Logic L55 dab 15 radio how do I tune it as do have the manual
LOGIK L55DAB10 INSTRUCTION MANUAL Pdf Download.
www.manualslib.com > Brands > Logik Manuals > Radio > L55DAB10
View and Download Logik L55DAB10 instruction manual online. ... DAB RadioInstruction Manual L55DAB10 L55DAB10_IB_110810_Zell.indd 1 10/08/2011 ...
Dec 16, 2015 | Audio Players & Recorders
I have a stock radio from a 1995 Kia Sephia, a kia logic control. I have the code to use, but when I do what the manual says the radio comes up with HOLD.
Good day and welcome to FixYa!
The radio has it's own memory which is powered by the car's battery. I strongly suggest that you remove the positive battery connector and leave it for atleast a minute then put it back on. This will reset the stereo system. Try punching in the code again.
Hope this helps and thank you for using FixYa!
Jan 05, 2015 | Kia Cars & Trucks
Having problem programming Pro-94, is there a simpler book or read than the manual. It says you must load in logical channel order. how do I determine this??? Also am I correct in that you can only load...
put your scanner in manual mode.and then go to program mode and program your frequencies into your scanner.try that and see if that works.....if not it could be a problem in your Radio....
Feb 22, 2011 | Radio Shack Pro-94 Scanner
I bought a new logic unit (front face) of Icom F121 and it needs to be restored. How do you restore a logic unit for the Icom F121?
1- You have to to "Reserve" mode.2- Change Set Mode Access: Inhibit to Enable3- Common>>Secutity Change Set Mode Access : Inhibit to Enable4- Enter RX TX frequency and write to the radio.
or you can download version Rev 1.7 from here:
http://www.two-way-radio-tools.com/icom-softwares.html
http://www.two-way-radio-tools.com/icom-radio.html
Aug 27, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
In radio mode, all speakers do not work
Radio will default to 2 channel stereo. You will need to use one of the soundfield processing modes to expand. Try using surround mode button to get to 6 channel or pro-logic.
Dec 29, 2009 | Sony STR-DE597 Receiver
Where can I get user and technical manuals for the Maxon sm-6150 radio?
you can usually get them from the manufacturers website. if you are hoping for a link, i'm sorry i don't have one for you. but the information i gave you is the logical solution.
Sep 09, 2009 | Radio Communications
Find manual for I-station Logic 3 clock radio
DO YOU KNOW WHERE I CAN OBTAIN A REMOTE CONTROL FOR THE PHILLIPS I POD DOCK MODEL NUMBER AJ3OOD?
Apr 28, 2009 | Logitech Audio Players & Recorders
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
