Question about Canon imageRUNNER 400S Copier
How to solve an eror e051, in a canon gp 405?
    Master:
  • Canon Master
  • 434 Answers
The horizontal registration home position detection mechanism has a fault
Posted on Jun 23, 2014
2 Suggested Answers
  • 118 Answers
SOURCE: Canon Gp 335 E051
E051 indicates that the side or horizontal registration sensor is not detected try to switch off/on the machine but if the same error code display again thereis a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Posted on Jul 21, 2009
My Canon copier, gp 405, Shows the error code : E 604. What is the problem ? How can I Solve it ?
Hi
This is an error on your Copiers memory,hard drive or the main controller board.Any of this may need changing.Have it checked.
Mar 02, 2012 | Canon imageRUNNER 400S Copier
I have a gp 405 error 051 pleace help me
The error code E051 deals with the duplex jogger arms.... Mostly,it is saying that when you are duplexing the arms that move to keep the paper straight in the duplex unit are not moving correctly. It is the motor and saw tooth gears. It is located above the paper feed unit.... Good Luck
Sep 12, 2011 | Canon imageRUNNER 400S Copier
Error code e220 for canon gp 405
That is a scan lamp error on all Canons that I know of. Check continuity on the lamp. Then check the in line fuse. It could also have a shorted scan cable.
Nov 09, 2009 | Canon GP-200 All-In-One Printer
Canon Gp 335 E051
Jul 17, 2009 | Canon imageRUNNER 400S Copier
051 code showing in gp 405
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again thre is a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 09, 2009 | Canon imageRUNNER 400S Copier
Canon GP 405 print error
The network card (ethernet pcb in the copier) has a fault, replace it.
May 05, 2009 | Canon imageRUNNER 400S Copier
CANON GP 405 ERROR E 051
My machine gave me an error E051 and it could not start. when i restarted, it still ended at that.
i decided to switch it off and wait for the technician to come and fix it.
the next morning i arrived before the technician came and when i switched on, it was very fine.
what could have happened.
Tonny Obwin Telecommunications engineer.
May 02, 2009 | Canon imageRUNNER 400S Copier
What is that eror code E000051-0000
E051-0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
because The horizontal home position sensor is faulty or the horizontal registration motor is faulty.
Dec 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
69 people viewed this question
old marine
old marine
