Question about e-Sixt Sixt Rent a Car
What is the alternative number to 08444740400
What is the alternative to 08444740400
I have a Toyota rav4 2009, 3.5l, 6 cyl I need to replace the bearings in the alternator, but nowhere can I find the numbers of these bearings and sizes. Can you help me?
the bearings are not toyota specific but are generic for the alternator manufacturer
Pull the unit apart and take the bearings to a bearing supply shop ( CBC , Timken etc) and the numbers on the bearings will identify them
You may get the numbers from an auto electrician who repairs alternators but it would be better to have the auto electrician recondition the unit completely
That way you will have a warranty and a serviceable unit
Mar 23, 2018 | Toyota Cars & Trucks
What is the alternative number to 08443722239?
I found an online reference to that number as from Barry Grainger Ltd, Insurance Brokers, 20 Chapman Way, Tunbridge Wells, Kent, TN2 3EF. A local alternative number shows as 01892 619 688
Apr 01, 2015 | Cars & Trucks
Need to rest my password
you can reset your password by using these three options
1. reset your password using alternate email id
2. reset your password using security questions
3. reset your password using your phone number
Jun 25, 2014 | gmail.com
Have a problem with login Yahoo and getting message saying "You are logging from device we won't recognise you" and I forgot my answer for secret question.
The prompt you are receiving is called "Second sign-in verification," and it is designed to protect your account from unauthorized access.
There are several ways to confirm your identity:
Send a code to mobile phone or non-Yahoo! alternate email address:
  1. Go to the Yahoo! sign-in page (http://login.yahoo.com).
  2. Enter your Yahoo! ID and password, then click Sign In.
    • You may need to enter the security CAPTCHA code. (If you do not see a randomly generated code, simply proceed to the next step.)
  3. Select Receive Code and enter your non-Yahoo! alternate email address or mobile number.
    • Note: A code will be sent to the location you entered; make sure you do not navigate away from the page where you entered your alternate email address or mobile number.
  4. Once you receive this code, you will need to enter the code on the page where you entered your alternate email address or mobile number.
    • You may be required to update your current password.
Note: At this time Yahoo! alternate email cannot be used to confirm your identity. If your alternate email address is a Yahoo! email, please use your mobile number or security question.
Verify your security question:
  1. Go to the Yahoo! sign-in page.
  3. Provide the answer for the security question displayed and click Verify Answer.
If you do not have a non-Yahoo! alternate email address, valid mobile number, or cannot verify your security question, you may need to contact Yahoo! to confirm your identity. Note: When filling out the form, please select Yahoo! Account under "Product."
Feb 14, 2013 | Yahoo Mail
Battery is died after using the tactor and then needs to be jumped?
There is the possibility that your battery is not being charged. I will need your engine model number to locate the part number and repair information for your engine alternator. If you have a one wire alternator the output is usually AC. Two wire alternators one wire is AC and the other wire is DC as measured at the connecting terminals by probing them while connected. I can provide you with service manuals for B&S, Kohler, Tecumseh, and Kawasaki engines. (Not Honda) to help you with repairs. I just need the ENGINE make and model number.
You could also have a blown fuse inthe charging cricuit depending on what make and model of the mower that you have. Usually if you have a blown fuse the unit does not run at all. There are some exceptions.
Without make and model numbers for both the engine and the mower. It is very difficult to help you professionally.
I suspect you either have a bad alternator, alternator wiring problem or a dead cell in the battery.
Thanks for choosing FixYa,
Kelly
May 01, 2011 | Garden
I can not locate the voltage regulator on my 1986 Jaguar XJ6 4.2. I have the symptoms
Hi, the regulator is integral to the alternator on your Jag.
Part Number: 14561 Weight: 13.0 lbs Warranty: Limited Lifetime Notes: 75 Amp alternatorPremium reman. Save the pulley, fan, shaftkey and/or fan spacer and mounting hardware from your failed alternator. You will need to install these parts on your replacement alternator. Unit Manufacturer: Lucas Amperage: 75 A Pulley Type: Sold without a pulley Fan: External Regulator: Internal Part Number: 14561 Weight: 13.0 lbs Warranty: Limited Lifetime Notes: 75 Amp alternatorPremium reman. Save the pulley, fan, shaftkey and/or fan spacer and mounting hardware from your failed alternator. You will need to install these parts on your replacement alternator. Unit Manufacturer: Lucas Amperage: 75 A Pulley Type: Sold without a pulley Fan: External Regulator: Internal Part Number: 14561 Weight: 13.0 lbs Warranty: Limited Lifetime Notes: 75 Amp alternatorPremium reman. Save the pulley, fan, shaftkey and/or fan spacer and mounting hardware from your failed alternator. You will need to install these parts on your replacement alternator. Unit Manufacturer: Lucas Amperage: 75 A Pulley Type: Sold without a pulley Fan: External Regulator: Internal
Mar 19, 2011 | Jaguar XJ6 Cars & Trucks
What alternator do i need for my isuzu trooper 3.1td citation part number amp etc thanks
80 amp alternator. Part number will depend on the place you get the alternator at.
Mar 19, 2011 | 1995 Isuzu Trooper
Am just wondering if a 98 explorer 2 doors has same alternator as 99 explorer 2dr?
Just get both generic part numbers from autozone or O'Reillys. If you use the Ford numbers the year number can show a different number in their part number sequence. Whether you can see the Amps rating on the alternator without removal is iffy.
Jul 07, 2009 | 1998 Ford Explorer
X-box live
Put any dsn number in alternate dsn field.It not matters.Make sure u put prefferd DNS right.If u dont know ur DNS numbers.Consult ur BroadBand service provider
Oct 23, 2007 | Dell Dimension 3000® Pentium® 4...
e-Sixt Sixt Rent a Car Logo
42 people viewed this question
Top e-Sixt Apps Experts
Brett Duxbury
Brett Duxbury
Are you an e-Sixt App Expert? Answer questions, earn points and help others
