Question about Mitel Superconsole 1000
How do i clear alarm code 145 and 146 on superconsole 1000?
It is also showing a message saying MAIN CONTROLLER failed at 00 00 00 00
2 Suggested Answers
ynotphone
  • 192 Answers
SOURCE: Mitel superconsole 1000
Yes, there are things you can do to clear the locked out phone.
~ The locked means something is wrong with the phone -or- wiring to the room from the Mitel system...
Locked out is like leaving your phone off hook too long, you get that irratating beeping noise, then when the beeping stops, the phone is locked out to save power going to the set.
Ok ~ the first thing I would try, go to the set and play with it, hang everything up and test to see if you can get dial tone... the next thing is change out the telephone set, and test.
If you changed out the telephone set, and there is still a trouble, there maybe a wiring issue, in which case you will require a cable tech to test connectivity...
Posted on Mar 24, 2009
How reset recorded message for wake up calls on mitel superconsole 1000
Your going to have to access the voicemail not the super console, try dialing the voicemail # then enter password.
Oct 31, 2017 | Cell Phones
How do I set up the messages for wake-ups and just the basic "no one is here" message?
You can download a copy of the manual from here: http://www.manualslib.com/manual/525349/Mitel-Superconsole-1000-Sx-200.html
Feb 19, 2015 | Mitel Superconsole 1000
I have a 150 hp Ingersoll rand aircompressor It is showing "Main motor overload. We have checked the motor and there is no issue with the motor. The computor has locked up and we can not clear the fau
Most faults on the main motor have to be cleared by resetting the main motor overload in the control panel first. Simply push the reset button the overload. Then reset the alarm on the controller. If the controller is locked up pull the main power disconnect for 15 to 20 minutes. Power the unit back up and try the process again. if no luck you will need to replace the controller and maybe the over load or aux contacts. If controller is truly locked your only option is to replace the controller.
Oct 20, 2014 | Ingersoll Rand Air Tools & Compressors
PHONE CALLING 911, i CANT DISENGAGE!
To read a 911 Emergency Call alarm message:
1.Press Function
2.Press [ALARM]
3.Press [SHOW 911]
This will show what extension calls the 911.
4.Record the number of the extension from which the 911 call originated.
If additional 911 calls were made, press [MORE] to view them.
To delete the 911 alarm, press [CLEAR]
5.Contact the appropriate emergency services.
6.Press [EXIT].
Apr 20, 2014 | Mitel Superconsole 1000
Tot major alarms
all "MAJOR" category alarms on a Mitel supeerconsole may or may not be service-affecting, but in any event need to be investigated, the cause found and cleared. Contact your Mitel service company or system maintainer. DO NOT IGNORE these alarms as you may come in some day and find your system completely down. (pay me now or pay me later) as the old saying goes. Good luck
Mar 31, 2014 | Mitel Lands Phones
IR2318L CANON COPIER IS SHOWING CODE E000003-0000 AND HAS STOPPED COPYING,WHAT COULD BE THE PROBLEM?
Heater temperature error (abnormal drop; low-temperature detection)
The main thermistor reading is lower than 140°C when paper is moved.
Main cause:
The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact
or has an open circuit; or, the fixing heater is faulty). The main power
supply PCB is faulty. The DC controller PCB is faulty.
Caution:
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. State
Turn on the power switch, and clear E002/E003. Thereafter, turn off and
then on the power switch. Does the fixing heater operate?
NO: See "The fixing heater fails to operate."
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 02, 2011 | Canon imageRUNNER 2200
Mar 23, 2009 | Mitel Lands Phones
We have the same problem at our hotel.
You can't fix it at the console, you need to go to the room and unplug the guest's phone from the wall for 10 seconds... reconnect and it is fixed.
Aug 23, 2008 | Lands Phones
Cant get rid of blinking error message, nothing works
The correct buttons to push in order to get into the service mode on a 162D are [#] key, [*] key, [C] key and [*] key. Then you key in 14 - 00 and press the Start key. If that fails to bring your machine back on, you'll have to replace the fusing assembly.
Apr 12, 2007 | Toshiba e-Studio162D Copier
Mitel Superconsole 1000 Logo
133 people viewed this question
Top Mitel Radio Communications Experts
eradiostore
eradiostore
Are you a Mitel Radio Communication Expert? Answer questions, earn points and help others
