Question about Canon PIXMA Office Equipment & Supplies
How do I Connect canon mx726 to billion router?
I have the AP name, security type and shared key but the printer will not connect to router.....please help
daemonguy
  • 118 Answers
SOURCE: help please....printer name does NOT appear
File and print sharing works over NETBIOS protocol , Make sure that NETBIOS over TCP/IP is enabled , some times NETBIOS forwarding is blocked by router firewall.
Follow these steps
1) make sure that both personal computer and laptop is on the same subnet for example
* Personal Computer IP : 192.168.1.2 Mask : 255.255.255.0
GateWay 192.168.1.1 (router)
* Laptop IP : 192.168.1.3 Mask : 255.255.255.0 Gw : 192.168.1.1(router)
* Wireless Router IP : 192.168.1.1 255.255.255.0
2) Enable File and Print Sharing on Personal Computer and share the printer as required
3) Enable Forward NETBIOS in the router , Check your firewalls manual for this step
4) In the laptop open printers and say add printer, and select network printer if you dont see shared printer in the list we have an alternative way
open Start --> Run and type \\192.168.1.2 if it ask username and password give username and password that you use in personal computer , In the opened window you can see the printer which is shared , Just double click it . It will install itself in the Laptop
Hope this would help solving the problem
Good Luck
Posted on Jan 27, 2008
  • 4 Answers
SOURCE: Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Posted on Dec 01, 2008
azz949
  • 55 Answers
SOURCE: NETGEAR WGR614v7 Network Security key
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
http://kbserver.netgear.com/kb_web_files/n101676.asp
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
Posted on Jan 25, 2009
  • 8 Answers
SOURCE: Epson px700w wireless
If you have wpa2 then it will not connect. I had the same problem. When i changed my router settings to wpa (you can chosse wep as well) the setup continued succesfully. You can also set the printer from its own menu without a pc.
Posted on Mar 21, 2009
kamal1984
  • 1383 Answers
SOURCE: AP does not work in Repeating Mode?
check your wi fi is enabled on ap settigns also che k broad cast ssid is enabled on it.
Posted on Apr 27, 2009
Instructions on how to connect my laptop to my adsl modem wirelessly.i have a 5200g billion router which is connected to my router via ethernet cable.i have a lenovo laptop with bluetooth.
Billion's BiPAC 5200G R4 is an economical ADSL2+ Firewall Router with 802.11g Wireless AP ideally designed for home and SOHO users to enjoy rich firewall security, mobility, and faster speed when using ADSL Internet connection.enabling system administrators to easily fit this security router into existing network environment and manage the IP assignment without reconfiguring your laptop with wifi.
Jul 13, 2011 | Computers & Internet
Helllo, Just purchase the D-link Air plus Xtreme G DWL-2100AP Wireless Access Point but I cannot access to put my username/password. I connected it directly to the ethernet from the wall but I can...
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the access point (192.168.0.50).
Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK.
Step 3 Click on the Advanced tab and then click Encryption on the left side. Select the Wireless Band (DWL-7100AP only).
Step 4 Click the radio button next to Shared Key and then click Enabled next to Encryption. Make sure your other wireless devices are set to Shared Key.
Step 5 Next to Key Type, select HEX or ASCII. You will need to use the same key on all your wireless devices.
· HEX - use 0-9 and A-F only.
· ASCII - All numbers and letters.
Step 6 Next to Key Size, select the level of encryption (64, 128, or 152-bit).
Step 7 You can enter up to 4 different keys. Select the key you want to use from the Valid Key drop-down.
Step 8 Enter your encryption key. You make this up yourself. If you selected HEX, then enter a key made up of a combination of numbers (0-9) and letters (A-F). For example - A4572BCC19 (HEX).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | D-Link AirPlus Xtreme G Wireless Access...
How to conect with wireless internet
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
Jan 21, 2011 | Computers & Internet
I hooked up my D'link to modem and computer and connection is good. But i can't find it when i search on laptop wireless connection. I think you need i driver but i can't find one. Thank You
4. Click Next.
B52Computers
Jan 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Can't get my lap top to connect wirelessly to my router. Model # WRT54G2. The laptop says it is reaquiring the network address, but nothing happens.
4. Click Next.
Jan 10, 2011 | Linksys Wireless-G WRT54G Router
I got this computer for christmas and I cant get it to connect to any wireless wifi system. I dont know what I'm doing wrong. Could you please give me some instructions on how to connect it to a home...
4. Click Next.
B52Computers
Chris Thrash
Jan 10, 2011 | Computers & Internet
Failed to connect to no response from ap...what is
What worked for me was to go into SETTINGS then NETWORK SETTINGS select CONNECTIONS then click your routers name then scroll down to NETWORK KEY type in your password and then SAVE then try connecting! hope it helps!
Nov 26, 2009 | Cell Phones
How do I set up my wireless Belkin F5D7050, I no longer have the CD. My computer has Windows Vista?
1. Hard wire your pc to the router/modem using ethernet cord / cat 5 cable or use usb storage to download the driver to this link
http://web.belkin.com/support/article/?lid=en&pid=F5D7050&aid=5381&scid=0
2. Install the driver/software by executing the file.
then follow this:
SymptomNot able to go online only with the wireless connection.
ResolutionTo address the problem, use the following steps:
  1. On the Belkin Wireless monitor utility click on the tab AP List .
  2. Select the encrypted network that you wish to join. Click Connect.
  3. This will take you to the New Profile page . Enter a Profile Name .
  4. On the next page, you will see the network name, the network type and the transmit rate. Click Next.
  5. This will take you to the page that will ask you to select the Authentication Mode. This will be OFF by default. Select Open System or Shared Key depending on the network.
  6. Then select 64-bit or 128-bit encryption depending on the configuration on the Router/AP. Click Next.
  7. On the next page, select Input Method , which will be Hexadecimal (0-9,A-F) or Passphrase.
  8. Select the key index and enter the keys or the passphrase depending on the configuration on the router/AP. Click Complete.
CauseYou are not able to connect to a secured wireless network because the router/AP (what is this?) is encrypted.
SummaryWireless networks by their very nature are not secure because data is transmitted across open (i.e., air) media. This allows unintended “listeners” to receive the data. WEP (Wired Equivalent Privacy) is used in a wireless network to secure the signals and hence the data.
Jul 12, 2009 | Belkin (F5D7633UK4A) Wireless Router
Connection - Zoom Wireless-G AP+4, model 4401
Cathy I have the same make and model maybe I can help. I speak both Tech and Non Tech so stop me if I lose you.
1. Did you go through the set up process of first connecting to your wireless router through the cable provide via your PC/Laptop?
2. Congfiguring your wirless via your browser http://10.0.0.200 ?
Sep 14, 2008 | Zoom (56600000) Router
Wireless internet connection
Hi, A couple of things you should check: 1. Has the "wireless internet user" enabled his Internet Sharing? If yes, how has is this user sharing it with you, through an AP/Router? 2. If he is using an AP/Router, are there any security settings enabled such as WEP, WPA, or MAC Filter? If yes, you have to get the security key and enter it into your configuration. 3. Is the DHCP Server in the AP/Router enabled? 4. If yes to #3, have you made your networking "Obtain an IP Address Automatically? 5. If no, you have to get/set the allowed IP address that you can use, Subnet Mask, Default Gateway and DNS Servers; 6. Can you ping the AP/Router or at least the "wireless internet" user IP Address. To ping, Start, Run, type "cmd", type "ping IP add of wireless internet user and/or AP/Router; 7. In your browser, enable Auto detect proxy settings for this connection; Pls post back with: a. How do you connect, a wifi card/USB or built-in? b. What AP/Router are you connecting to? c. What browser are you using, IE, Mozilla, Opera? Hope this be of some help/idea. Good luck and kind regards.
Sep 19, 2007 | Compaq Armada M700 Notebook
19 people viewed this question
old marine
old marine
