Question about Hardware & Accessories
Need to keep chain tight.
This is a vehicle lift. Each side has a screw gear. They are driven by a hydraulic motor at the top on either side. At the bottom is a chain that just keeps both guitars in sync with each other. I need to keep them tight going in either direction.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
If it's a chain, is it not possible to remove a few links to tighten it?
Posted on Jun 22, 2014
How do I open my garage door
It sounds like there is a stripped gear in either the motor or that the gear on the motor is slipping on the motor shaft. Get up to where you can see the drive gear where the chain/belt/brace attaches to the motor. Have someone try to open the garage door while you WATCH what happens during this time. KEEP YOUR HANDS, CLOTHING, JEWELRY, HAIR and ANYTHING ELSE AWAY FROM THE OPENER WHILE PERFORMING THIS STEP - SERIOUS INJURY COULD RESULT!
If the motor is turning and the door still doesn't open, see if there is a allen wrench (hex key) screw somewhere on the part that lifts the door. Try to tighten it down and if you can, make sure it's tight.
Your door should now open.
Oct 18, 2014 | Building Materials
Top worked fine yesterday but today tried to let down only clicked
It is a hydraulic pump that applies pressure to the 2 hydraulic pistons to raise & lower the top. So, check for something obstructing movement first.
The convertible top:
  • is motor-driven.
  • requires parking brake engaged to complete circuit for operation.
  • is equipped with a back window glass (42006) . The back window glass is permanently attached to the folding top back window curtain (52500) and cannot be opened.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged fluid reservoir.
  • Damaged folding top hydraulic cylinders .
  • Damaged folding top motor upper and lower hose .
  • Damaged convertible top regulator.
  • Parking brake not engaged.
  • Open power distribution box circuit breaker CONV TOP (30A), fuse junction panel Fuse 1 (15A).
  • Circuitry open/shorted.
  • Damaged convertible top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Convertible Top Does Not Raise/Lower
  • Open circuit breaker or fuse.
  • Damaged folding top switch.
Jun 29, 2011 | 1998 Ford Mustang
I have a Poulan ES 350 and need to know how to put chain back on and tighten.
Start by removing the cover securing nut, remove the side cover,wind the chain adjuster screw at the front of the saw anti clockwise, until the old chain becomes lose, pull the guide bar out and off the adjuster pawl, should now be able to remove the old chain, loop the new chain over the sprocket, and into the guide bar rails, make sure the cutting edge of the chain on the top of the bar is facing away from the saw ( the chain rotates clockwise as you look at it )make sure the bar is still located on the adjuster pawl, re fit the side cover, re fit the securing nut finger tight, now turn the adjuster screw with a flat blade screw driver, until the chain sits snugley in the bar rails, there should be no sagging on the bottom of the bar, now lift the tip of the bar and fully tighten the securing nut, run the saw for a couple of minutes, now re check the tention. The correct tention is so you can lift clear two of the drive teeth out from the top of the bar.
Mar 14, 2011 | Poulan ES350 16" Chain Saw
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Ovne do not turne withe rack in side the ovne
Does the rack raise? Are you hearing a buzzing every second? You could have a bad rotation motor, or the drive chain could have just fallen off. Both of these repairs aren't terribly difficult but are extremely annoying. It might be a best use of your time and resources to call an authorized service provider and have them repair the issue.
If you're feeling ambitious the first thing you want to do is verify that your rotation motor is still functioning and that the gearbox is not stripped out. Make sure the supply power to the oven is off, climb up on top of the oven and remove the covers over the lift and rotation assembly if they are not already removed. You should see a black cylindrical motor with a plastic fan blade on the top, this is your rotation motor. Spin the fan blade with your finger while looking at the motor shaft, it should be rotating, if it is not you need a new motor. To change your rotation motor you will need a 5/16" ratcheting box wrench and it can be a nightmare the first time you change one. Unwire the motor, pay attention to which wires you disconnected. Remove the four screws underneath the motor and slide the motor straight up through the hole. Change the chain sprocket over to your new motor and reverse the steps.
If your motor IS rotating when you spin the fan then your chain may have slipped off. Loosen the four screws holding the rotation motor in place so you can slide it back and forth. Lift up on the shaft and place a screw driver in between the metal disc above the big sprocket to keep the weight off of the sprocket. Put the chain on the small sprocket first and then slowly work the chain onto the large sprocket. Once the chain is on lower the shaft back down and tighten the motor back up. Hopefully your rack should start rotating again, if it doesn't the gears in the gearbox could still be stripped causing it to slip, in which case you should call an authorized service provider to service the oven, or see above.
Aug 17, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Ryobi 540A need manual runs slow/ chain too tight?
Actually, I own one of these battery operated Ryobi chain saws too. It is normal for the saw to run slow. Remember it is battery powered, not gas, so its not going to be a high rpm saw. Be patient whit it, and you'll get about 4-6 cuts per battery. I take mine camping. It sure is nice not having to listen to a two-stroke while relaxing in the woods! Dont plan on cutting lots of stuff, either, or you'll burn up the motor. This thing works great for very mild workloads.
Aug 14, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Garage door doesn't open or close
You should check the gears inside the box, After years , the gears get dry and die, you can by online or from Sears the kit and replace the old gears. I just changed mine...not too difficult :) .
Mar 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
KitchenAid 2671 Mixer always wiggling
I have had the same problem to remove the motor you need to remove the two screws at the back of the motor next the two screws holding on the circuit board (so you can get at the screws around the gearbox ) next remove the cover on the gearbox by removing the four screws and lift off after you have done this you can lift the motor out but remember you still have the wires connected but you can get at the screws to tighten the head down try using lock-tight on the screws
Jan 28, 2009 | KitchenAid KP2671 Professional 6 Series...
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Go to Pinpoint Test D.
Jan 04, 2009 | 1989 Ford Mustang
Chain
Put it up on your stand lossen the axel and remove the bolt on the bottom of the shock. Then tighten your chain and lift your swingarm up until its horizontal with the ground, then the chain should have almost no play. Not completely tight, but almost no play. Tighten the axel, and the bolt on the shock, and your set,,,
Nov 10, 2008 | 2001 KTM SX 125
Hardware & Accessories Logo
268 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
