Question about Coffee Makers & Espresso Machines
My aldi coffee machine is leaking the water into the bottom of machine.
K-Fee Expressi coffee machine, water is leaking into the bottom of unit instead of thru' the capsule.?
  • 4 Answers
SOURCE: Unit leaks out of the bottom
Mine just developed the same problem. Me being an engineer, I decided to take it apart and found the problem. There is an aluminum tube shaped like a "C" with a heating element inside of it. Water flows through this metal tube, is heated, and then pushed via steam pressure. There is a metal brace that holds this "C" piece securely to the bottom of the machine. This brace is sharp and overtightened, which caused a small hole to form in the metal, causing the leak (in my machine of course). I am currently researching how to patch aluminum so I can hopefully fix it.
Posted on Jan 06, 2008
  • 5 Answers
SOURCE: Bunn Coffee Maker Leaks out the bottom
The water that leaks is cold. It's leaking from the top. Unscrew two screws on the sides of the water-in grate. Lift off and put aside. The next level has 4 screws. Unscrew and put aside. Where the water enters the heating cannister, there is a clear grommet. It pulls off. Put a ring of silicone caulking on the cannister side of grommet and put it back. Press to get a good seal. Now the top part of the grommet also needs a seal. Take the second level piece and put a bead of caulk on outside of hole that goes over the grommet. Press for seal. After caulk has set is should be all-set to use. toms
Posted on May 29, 2008
Cuisinexpert
  • 61 Answers
SOURCE: water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Posted on Aug 27, 2009
SOURCE: cOFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
Posted on Dec 10, 2010
SOURCE: No coffee comes out, only
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
Posted on Dec 13, 2011
Machine leaking water
What type of machine would help
Oct 24, 2017 | Coffee Makers & Espresso Machines
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
Bunnamatic is leaking out of bottom of unit
Contact Bunn online. They will send you a repair kit with instructions.
Mar 23, 2013 | Bunn 10 Cup Home Coffee Brewer
Water leaks from bottom of unit when making a pot of coffee
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
May 06, 2010 | Waring Pro® WC1000
Leaks water from bottom when brewing coffee or using steam unit
If it is coffee colored water, check the chamber under the white plastic valve behind the brew unit, that might be blocked with coffee grounds. If it is clean water one of the lines might need new o-rings.
Apr 14, 2010 | Gaggia Titanium Espresso Machine
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
Shots are small, and water leaks from bottom of unit
You machine has an internal leak and this is why you shots were getting smaller and smaller. The more time goes by the more it leaks, hense, the reason for smaller shots.
You should have someone look at your machine.
Saeco Service Center for New York
www.cerinicoffee.com
Nov 21, 2007 | Gaggia Syncrony Espresso Machine
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Coffee Makers & Espresso Machines Logo
2,364 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
