Question about Apple iBook G4 Mac Notebook
How do i get rid of the blue dock bar
I made the things on my dock menu smaller but it left the blue bar is there a way to shrink it?
    Problem Solver:
  • 11 Answers
hope this video helps. right click the dock preference.
Posted on May 14, 2014
Stop one mac screen from becoming multiple screens
Mirroring displays the same image on each display.
  1. Make sure your additional display is properly connected and powered on.
  2. From the Apple (?) menu, choose System Preferences.
  3. From the View menu, choose Displays.
  4. Click the Arrangement tab.
  5. Enable (check) "Mirror Displays" in the bottom-left corner.
In the example below. the blue boxes represent each display that is connected. The white bar at the top of both boxes represents your menu bar and is shown on both displays when they are showing the same information.
When mirroring, your Mac attempts to match the closest resolution between the primary (or built-in) and secondary displays.
The usable resolution is the closest matching resolution for both the primary and secondary display. If you choose a resolution that is not supported on both displays, OS X reverts to using the closest matching resolution.
Extended desktop With extended desktop, your displays are treated as one, continuous desktop.
  1. Make sure each display is properly connected and powered on.
  5. Disable (uncheck) "Mirror Displays".
In the Displays pane of System Preferences, each blue box represents a display that is currently connected. The size of each box is relative to the current resolution of the display it represents. In the example pictured below, the larger box on the left represents an Apple 27" Thunderbolt Display, while the smaller box on the right is the built-in display of a 13" MacBook Air (Color LCD).
The white bar at the top of the left blue box represents the menu bar you see at the top of your display. Menu bar placement determines which display is treated as the primary display in OS X. To change your primary display, click and drag the white bar from one blue box to another.
You can also drag any of the blue boxes to change a display's represented location. Use this feature to make sure the connected displays match their real world location when navigating your desktop.
As shown below, each display retains its maximum resolution setting as they are operating as individual displays showing a continuous desktop.
lion_choose_max_resolution_.pngPress Command-F1 to toggle between video mirroring and extended desktop
Press Command-F2 to detect displays
May 01, 2014 | Apple 24" iMac Desktop
How I delete a bookmark from front page
  • Open Safari by clicking on the Safari icon in your Application Dock. If you do not have Safari in your dock, click the Finder icon in your dock to open the Finder window. Click on the Applicationsicon1.png icon in the far left column of you Finder window, and then double-click the Safari icon.
  • 2 Identify the bookmarks you would like to keep and the ones you would like to delete. Safari has a bookmarks bar and a bookmarks pull-down tab. Delete bookmarks that are saved on your bookmark bar by hovering the arrow over the bookmark you want to delete. Press and hold the "Control" key and click your mouse pad. A pull-down menu will appear; highlight the "delete" option and click your mouse pad. The tab will now be deleted from your bookmark bar.
  • 3 Delete bookmarks in the pull-down menu by clicking the Bookmark tab at the top of your screen. Select the first option called, "Show all bookmarks." Select the "Bookmarks Menu" option in the left hand column of the window that pops up. Hover the arrow over the bookmark you want to delete. Press and hold the "Control" key and click your mouse pad. A pull-down menu will appear; highlight the "delete" option and click your mouse pad. The tab will now be deleted from your bookmark bar.
  • Read more:
    Apr 21, 2014 | Apple safari
    My gps is lock home page will not reset will not cut off are onff or
    I plunged mine in to the the computer and left it all night then held the off switch in for several seconds and mine reset plus I did an update before i shut it down. Hope this helps your's
    Apr 17, 2014 | Rand Mcnally Intelliroute TND 510 Truck...
    Some of my desktop icons have grown to be very big. I want small icons.
    in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
    in windows xp;
    Shrinking Icons in Windows XP
    • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
    • 2 In the "Display Properties" box, click on the "Settings" tab.
    • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
    • 4 Click on "Apply" and then click on "OK."
    • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
    • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
    • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
    • 8 Click on "Apply" and then click on "OK" to adjust the size.
    Shrinking Icons in Windows Vista
    • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
    • 10 Right-click on the desktop again and click on "Personalize."
    • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
    • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
    • 13 Click on "Customize."
    • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
    Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
    Sep 08, 2013 | Computers & Internet
    When I down loaded Gimp it was working fine Then out of the blue everything froze and a window came up an said the driver stopped working. I uninstalled Gimp and re installed it , then re installed it ....
    Just HOLD CTRL and tap . You could also click on the word WINDOW in your GIMP menu bar and click on dock able dialogs and then layers OR below that click on LAYER, CHANNELS,......
    Aug 07, 2010 | GIMP GNU Image Manipulation Program
    Hello; when i trun on my macbook the screen did not show the table which has safari and msn and all the programs? can any one help me plz?
    I think you mean the Dock at the bottom of your screen with program icons on it, right?
    If so, move your mouse all the way to the very bottom of the screen. Your Dock should appear. It may be set to hide automatically.
    If you don't want it to hide, click on the Apple menu (in the top, left corner of your screen), then click "System Preferences". Next click "Dock". Finally, click the button to the left of where it says "Automatically show and hide the Dock." That should get rid of the check mark that is there and stop your Dock from hiding.
    Please rate me if this solves your problem. Please let us know if it doesn't work so we can give you further assistance.
    Bot
    Jun 29, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
    Desktop is blank except for the mouse which does move. There is no task bar and I am unable to boot to a CD holding down the C key?
    By task bar, I am unsure if you mean the upper menu bar, or the Dock.
    The Dock can be placed on any of the four walls of the screen. Approach each edge with the mouse and see if a Dock appears. If not, go to the Apple menu / System Preferences / Dock, and turn hiding off.
    If, on the other hand, you have no upper menu bar, you have some sort of unusual system corruption, and may want to think about reloading the system.
    There are two alternate ways to boot from a CD/DVD. One is to hold down the option key at boot, and choose the CD icon when it appears. Another is to hold down the four keys delete, option, command, and shift at boot—this is a much older sequence and less useful, but occasionally works when nothing else will.
    Apr 08, 2010 | Apple iBook G4 Mac Notebook
    Picture gets smaller from left to right (tunnels)
    if the image shrinks and not just the size of the image, reset the settings to factory default through the menu. if it is just the screen and it crops the image as it shrinks, it may be that the light tunnel has collapsed and needs replacing.
    Aug 28, 2009 | Mitsubishi HD4000 Multimedia Projector
    Tv picture is shrinking.
    Check for dry electrolitic capacitors near the vertical IC
    Jun 23, 2009 | Philips 27PT563S 27" TV
    Apple iBook G4 Mac Notebook Logo
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
