Question about Cameras
How to repair lcd screen
I dropped my nextbook and now when i turn it on it's simply a white/gray screen.
    Top Expert:
  • Cameras Master
  • 6,702 Answers
You could check out ifixit.com, There they have manuals, videos and more, how to repair lots and lots of electronic stuff. Also tablets. They even can send you spare parts or tools if you need it.
Not sure they already did your model, but on the other hand you did not give an accurate type or model number.
Success
Posted on May 14, 2014
How to fix it, i dropped my nextbook on carpet and now nextbook turns on but nothing but green and white screen
You damaged the display screen. It needs to be replaced with a new one. It will not be a cheap repair. Estimated cost to repair is around 175.00. It will be cheaper to buy a new nextbook tablet.
Jun 08, 2014 | Tablets & eReaders
I dropped my phone and it turned white with colored lines in ot bit I can see half of the screen
I had a BB9900 and while I did not drop it, my screen too when white with rainbow coloured lines across a portion of it. The screen was not repairable; simply replace it. Before you do, consider simply changing up your hardware entirely as the cost differential between a screen replacement and new device can (depends on many variables) be nominal.
Mar 11, 2014 | 3M Post-it Purse-shaped Note Dispenser -...
My pc is showing a white screen when iys on
Is it an LCD monitor ?
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
I dropped my phone and now the screen is white with gray lines. is this fixable? or does this mean i need a new phone?
Sorry but your lcd screen needs replacement. Take it to the apple store and see if they'll give you a replacement. If they don't there are third party iPhone Repair Services that can fix it for you. There are also free iPhone Repair guide that show you how to fix it yourself. The part is on Ebay.
Oct 10, 2009 | Apple iPhone 3G
Dropped camera. Now screen is part picture, part
maybe your lcd screen is broken.
you could try to buy a replacement and fix up it yourself.
from belwo you will find it.
http://szaideal.diytrade.com/sdp/975724/4/pl-4820089/0/Product_Catalog.html
Sep 10, 2009 | Cameras
Dropped itouch now half of screen is gray everything else works fine just can't see half the screen
It's most likely a broken LCD. You can use a ipod repair guide that will show you how to replace the screen step by step, or you can go to the ipod repair nyc.
Jul 20, 2009 | Apple iPod touch
Iphone display doesn't work after it dropped
You have broken the Liquid Crystal Display (LCD) the touch screen digitizer and front glass is a seperate unit so that is why it still works. The LCD is the visual part and can be purchased online and fitted yourself if you feel up to it and is not that expensive, Videos of how to do it also on youtube. Or you can take it to a mobile repair centre to get them to do it for you.
May 28, 2009 | Apple iPhone 3G Black Smartphone
Iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
Apr 04, 2009 | Apple iPhone 3G
Shutter won't open when turned on. Screen is gray & alarm sounds
It sounds as if when the camera was dropped it impacted the image processing chip inside of the camera thus why the LCD screen appears gray in color. You may want to call Olympus and discuss repair options. Their telephone number is 800-622-6372 option 2 and then option 3.
Nov 19, 2008 | Olympus Stylus 1010 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
